caliper handbrake lever seals
Old May 13, 2012 | 08:12 PM
baggy1979's Avatar
baggy1979
RS geek
Default caliper handbrake lever seals
Hi all i am in the process of rebuilding a set of 4x4 rear calipers.They are all stripped and shot blasted my new seal kit has arrived and there is a seal i am unsure about. There are three for the handbrake lever one is a dust seal which sits at the top of the lever rod, one is a o-ring which is for the threaded wind back piston rod, and the other is a lipped seal which im unsure were it goes as i didnt see one like it when i stripped them.Has anyone rebuilt these calipers before who could tell me where they go many thanks.
Old Jun 2, 2012 | 11:11 AM
BRAMMER's Avatar
BRAMMER
Just doing mine - the 3rd seal is for the piston - remove the circlip and star and copper washer and remove the large part in the base - the seal is on the other end remove but note which way it is fitted before removal
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
