What a difference.....wish I had done it ages ago
I have just finished fitting all new VITON seals to front end of engine (Stage 3 Sapphire 4x4) and fitted yet another cam belt when I took the time to align the rotor arm EXACTLY to the mark on the dizzy by removing rotor and used the slot on top of dizzy drive instead. WOW didn't know it was so important (my thanks to Tabetha) now my car has really come alive.........
More power all across the range including off boost
Spools up earlier and slightly more boost without touching actuator
Much better idle
Better fuel consumption (slightly)
Better low speed driveability
Much quieter
Best of all it solved my cam belt problem where it was stretching when hot and eating belts. The car was obviously running retarded and hotter so more expansion of head, too tight cambelt..................better than that NO oil leaks thanks to VITON and put a breather in cam cover as well as all the others.
Super pleased
Much better idle
Much quieter
Super pleased
Im sure i seen on here he got banned or sumthn.. and as for the disy thing,you have got me wondering! So after u set it and put rotor bk on and lookd,was the line on rotor not lined up with line on disy??
What sort of crap politics would ban a man like tabetha??? What I would give for half his cossie brain ...
I am intrigued about this dizzy set up ... Also a bit gutted to hear about tabethas ban .what did he do ??? Did he say scooby better than bossie ?
Thats right as you cannot actually see the mark on the dizzy as the rotor arm is in the way and the inlet manifold. I am guessing I moved it between .25 and .5 of an inch, now others on here say that the car wont run if it is too far out and that the ECU takes over, but it worked for me its great
As said above you cannot actually see the mark mainly because of the inlet tube on No. 1 cyl so I was sort of guessing the mark was in the middle of thr brass bit of rotor arm
Yeah what happened to him, I always found his info to be spot on and he has helped me no end as you can probably see I'm along way from you guys (Canada) and its not like I can drop in and see anyone for advice
Bring back Tabetha
Bring back Tabetha
Bring back Tabetha
Bring back Tabetha
Bring back Tabetha
Bring back Tabetha
Bring back Tabetha
Bring back Tabetha
this was discussed ages ago and he is definitely not coming back
he went on a wild one and gave a load of abuse to mods and even the owners of the site, so even they don't want him back, even if we wanted to, not like chop
Ok fair enough, I'll get back to rattling on about how well my Cossie is going. I feel like never messing around with it again as they say "If it aint broke don't fix it"
Kiran1600E
11
Oct 2, 2015 11:35 AM
rsguy
44
Sep 29, 2015 03:29 PM
deathrider666
Sep 28, 2015 06:12 PM
