Fuel pump carrier difference 3dr/Sapp etc
Old May 12, 2012 | 11:03 PM
BRAMMER's Avatar
BRAMMER
Default Fuel pump carrier difference 3dr/Sapp etc
Were the Sapphire onwards revised as all the 3dr ones i've seen including my own seem to be different on the pump side underneath like an extra piece
For example this one i pinched off the net is the same as mine
You can see the base part of the pump side then the fuel pump fitted and the top part just hocks on one side of the lower part and bolts tother side
Other type - doesn't use the 2 semi round parts where the rubber bush with the slits in this has 2 bolts to the left of the pump
Old May 14, 2012 | 07:36 PM
cozzy jeff's Avatar
cozzy jeff
chris from what i understand the bottom one is off a sapp,they used them little rubber bobbins to help with vibration and noise.
Old May 14, 2012 | 07:48 PM
Paul_RS's Avatar
Paul_RS
Top one is the revised version IIRC, my sapphire has the bottom one on it. Pretty sure the only difference is the the fuel pump clamp and its mounts, rest is the same.
Old May 14, 2012 | 08:26 PM
Sonic Boom's Avatar
Sonic Boom
I have the top one fitted to my 3 Door, so it must have been changed sometime it's life.
Rich
Old May 14, 2012 | 10:03 PM
cossiedad's Avatar
cossiedad
The rubber bobbins, or bushes, are different. One of them is the same as 2.8 or 2.9 Granada ones. Think it was the mk3 Granada with the Essex engine. Either way, both no longer available from Ford. Both can be used though, just depends which you have that is in the best condition.
cheeRS
Old May 14, 2012 | 10:56 PM
Paul_RS's Avatar
Paul_RS
The rubber mounts are still availible, at something like Ł15 EACH My parts man felt bad for me that day lol
Old May 15, 2012 | 11:56 PM
BRAMMER's Avatar
BRAMMER
I have the top one but wanted to change the rubbers but nla like everything else - I thought mine was missing a part to start with but not
cossie09
Sep 14, 2015 04:21 PM
jonjg
Sep 1, 2015 03:46 PM
ekjim
Aug 27, 2015 05:20 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
kosienutter
31
Aug 22, 2015 09:55 AM
