ford focus rear wheel bearings
Old May 6, 2012 | 08:52 PM
mumto4focus's Avatar
mumto4focus
Default ford focus rear wheel bearings
Hi i have a 2000 focus and i am just wondering how easy or hard it is to change the rear wheel bearing,
It is screaming at me and is very annoying,
Could somebody tell a how to and also if it is pressed in, many thanks
Ann
Old May 6, 2012 | 09:25 PM
studabear's Avatar
studabear
pressed in, very easy if you have a press. torque setting is 235nm
Where are you in the north west?
Old May 6, 2012 | 09:26 PM
Andy Tucker's Avatar
Andy Tucker
Welsh And Proud
I done mine myself using my mates press.not that hard tojust make sure you press the new ones in straight.
I think to get the old ones out I used a big socket bit.
Hope this helps.
Old May 6, 2012 | 09:29 PM
mumto4focus
i am near blackburn,
i have nicley talked the fella to fix it for me but he was not sure if was pressed or not.
Old May 6, 2012 | 09:31 PM
mumto4focus
thanks i will show fella post and he can see what you saying cause if he screws it up he cant blame me n will be all down to him
Old May 6, 2012 | 09:56 PM
studabear's Avatar
studabear
remove wheel, remove dust cover, undo hub nut, release handbrake, pull drum off, remove circlip from bearing, press bearing out, press new bearing in, replace circlip, push drum back on, torque new hub nut to 235nm, rpelace dust cover, replace wheel.
Make sure the car is safely supported while working on it.
Old May 7, 2012 | 06:04 PM
I did my wifes 53 focus zetec with drums on the back and that took me about 40 mins to do.
Old May 14, 2012 | 11:28 AM
mumto4focus
i got discs on the back of mine
Old May 14, 2012 | 11:34 AM
studabear's Avatar
studabear
its a similar procedure
Old May 18, 2012 | 06:15 PM
mumto4focus
ok thanks alot just waiting for weather to get bit better x
Old May 18, 2012 | 09:09 PM
Is the rear wheel bearing the same for all the focuses???
Old May 19, 2012 | 02:13 PM
mumto4focus
i am not sure but when i checked a online shop it came up with different types as i werent sure i got mine from a car shop
malkiemac3579
Jul 14, 2017 12:10 PM
track.focus'd
Aug 12, 2015 05:53 PM
taylora1409
Aug 12, 2015 12:06 PM
muz
Aug 1, 2015 06:48 AM
