Minimum cossie head thickness????
Start off new about 139.2mm dave, so 0.5mm or so (20 thou) potential to take off.
Unless you get lucky, that will be a couple of skims.
I just had mine done, it was unskimmed to start with and not warped, but just to get the face clean and free from the effects of corrosion on the surface round waterways due to an ageing gasket took just over 8 thou (0.2mm)
PassionFords Creator
Brad,
Its a misconception that the head becomes "Too thin, or weak" and also that its about the altered "Compression Ratio"
The issue is the area around the valve seat becomes dangerously thin after 138.68mm. As a last resort the head can be diagonally skimmed if the damage is around teh exhaust side, but a new casting is of course the proffessionals prefferred choice.
Im sure someone can pop some pics on here to illustrate a meaty head and a fooked one??
Is this all talk too about the brass thing in the head.
What is the best thing to use to clean the crappy bits of gasket off too, need this done on mine as fitting a metal gasket.
Don't want to get it skimmed just for the sake of a clean.
Dave.
Dave.
Originally Posted by DazC
So a head at 138.4 is pretty much scrap then!
Daz, could you not use the thicker gaskets.
Could be used for a low comp engine maybe, or , a normally aspirated engine.
Dave.
Dave.
Dave.
p,s cheers stu
Dave.
Dave.
Have heard similar things.
WTF is it anyway...lol.
Dave.
Brad,
Thats deffo reliable info as i know a twat who does it and then flogs em
Dave,
Read the reason again why 138.68 is the ideal minimum to answer your own question...
Daz,
Depends on application. Is it that depth on both sides?
Dave,
Daz,
Originally Posted by frog
Stu, what do you mean by diagonally skimmed ? I don't get it
Set the machine up so you take more meat from the exhaust side than the inlet side basically.
Originally Posted by Stu @ M Developments
Daz,
The car is going to be built as a 7.5:1 for T34 and 30 psi on greys...
Now, what about decompression plates ? Are they any good to make up the lost thickness (assuming there's enough meat around the valve seats as you said above stu) ?
If theres enough meat aroundthe valve seats, decompression plate is pointless and uneeded.
Anyway, its a poxy idea at best and totally ruins a carefully calculated squish area, ofton promoting det almost as well as lopping the top off of your pistons
no no no, just need circles and red arrows
stu essays are confusing and i have to phone uo and ask kenny to explain in a way i can understand
hes answer is usually ill leave a note for stu on his desk and if theres a problem he will ring ya
how can u get the comp ratio lowered without getting the pistons decked ?
A very talentless illustration of the area that becomes too thin....
Things are much clearer now thanks - ginge how about you ?
Bowl the head out ???
Its a tad late to get into a technical essay about squish, but very briefly:
The squish area is the thinest area between piston and cylinder head and is usually engineered to be the full circumference of the piston.
The purpose of this very close area is to force as much of the potent fuel mixture to the center of the clearance volume as possible, so when the burn is initiated we have maximum progression from the kernel of the mixture with a nice even and progressive burn outwards.
Having loose pockets of fuel in the area around the cylinder walls can result in a mixture that can, when the cylinder pressures rise, spontaneously combust, and start to destroy the surrounding metal, much the same as is evident in some of the above pictures.
Often, removing squish will be deemed to have "Fixed" an awkward engine, when in fact, the lowered CR was in fact the alteration that had the effect. This lower compression cylinder with higher squish clearance is actually more prone to det than one left alone and bowled in most cases, due to the aforementioned reasons
The moral?
Get a Pro to BOWL out your pistons, not hacksaw teh fookin tops off
This is pleasure for me pal, i enjoy chattin shit to folks, its better than watching tv etc IMO.
The moral?
brad,
Stu do you ever finish workin m8 ?
Stu,
could you not resit the valve seats further in and lob a bit off the valve tips.
Dave.
Dave.
A very experienced machinist could indeed do this with some reshaping of the chambers, yes. However, ive seen a few done over the years and they tend to be a bit poor IMO with some valve seat failures recorded after havng it done. Thankfully none of my customers.
Deffo a discussion i must have with Karl though if i can ever get hold of him
So from the above, a dished piston is better than one that has four little pockets (from a combustion point of view), cos the one with the four pockets would appear "domed" rather than "bowled" ?
Anyway, time for bed now, thanks for the educational session stu
