Starting Problems
Old Feb 28, 2005 | 08:38 PM
D_a-RR-e_N's Avatar
D_a-RR-e_N
Default Starting Problems
Can any one help me ?
my van was really bad and had top end rattle, so changed cam and started to run better, then i think it sliped a tooth or 2 cos start to run shite again, last night, sorted timing out again and it fired up but over reving and couldnt controll it, could only controll it by screwin a screw on meatering head,
went back out tonight to fire it up and wouldnt fire ?
theres fuel getting through and theres a spark?
Olny thing is which its never done b4, the Flap on the meatering head is flaping (opening and closing fast) when i turn it over??
any ideas cheers,
ERST motor by the way
Old Feb 28, 2005 | 08:55 PM
DanRSturbo's Avatar
DanRSturbo
Which way did you turn the screw on the metering unit ? Is the opening and closing quickly not letting enough fule through, or letting too fuel thorugh, queue a mechanic on that one
Old Feb 28, 2005 | 09:34 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
the flaps meant to bob up an down as it turns over, the vacuum (which the engine works on) pulls it open.
Old Feb 28, 2005 | 10:03 PM
D_a-RR-e_N's Avatar
D_a-RR-e_N
right sorted that got it running, but how are you ment to set meatering head up ?
Old Feb 28, 2005 | 10:45 PM
vroooom ptssssh
It Wasnt Me!
ring your tuner
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
muffster
13
Sep 3, 2015 09:40 PM
nick8saff
Aug 16, 2015 05:35 PM
Sjieter
Aug 5, 2015 09:47 PM
