Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Instrament Cluster Swap
Old May 4, 2012 | 04:28 PM
genralcheese's Avatar
genralcheese
Question Instrament Cluster Swap
I need someone abit techy here. I have a fiesta MK6 and my lcd on the speedo cluster stopped working, so I cant tell how much petrol I have in the car. I've replaced the lcd with one from another, which shows the same problem so I know its on the actual instrament board it self. I swaped the complete unit from another fiesta mk6 with same engine size, all works accept the car won't start. Does the new instrament need to be reprogrammed by ford or is there a connection kit which connects to a laptop like the code scanner so I can do it myself.
Any help would be much appreciated.
Old May 4, 2012 | 06:58 PM
RichieST's Avatar
RichieST
It will need a trip to Ford to be programmed as it's all tied in with the immobiliser.
Old May 4, 2012 | 09:37 PM
genralcheese
When you say the imobiliser, do you mean the ecu needs to be reprogramed or the keys ect..
I spoke to ford and they want £300+ to reprogram the new instrament cluster, which is out of the question, do you know if there is a kit I can buy to do it myself
Old May 4, 2012 | 10:06 PM
arse end happy's Avatar
arse end happy
ive got a guy who might be able to sort that for you he can reprogram keys an imob i aint got his number till i go back to work tues but he is mobile
Old May 4, 2012 | 10:08 PM
RichieST's Avatar
RichieST
the proper kit is thousands of pounds. Could be worth finding a mobile diagnostics technician to do it. Ford are having you over, won't take long to do on their computer, I'd expect to pay no more than an hours labour rate. Maybe try another dealer?
Old May 4, 2012 | 10:17 PM
genralcheese
Thanks for your input, I'll try some other dealers, doe's it have to be ford or can most repair centers do it? If you have that number that would be great, I'm in the london area so don't know if your guy is around this way.
Old May 4, 2012 | 10:18 PM
genralcheese
Sorry forgot to say on the new cluster the milage is lower, can they reprograme it so my milage remains true to my actual milage?
Old May 4, 2012 | 11:05 PM
GVK.'s Avatar
GVK.
On some Fords (using the Ford IDS) you can write the mileage to odometer, but I think it can only be done on a new cluster, can not 'clock it' to a lower mileage and you only get one chance.
Some of these 'digital dash experts' may have aftermarket tools to 'adjust mileage' on a second hand dash.
£300 to program a dash takes the piss it takes a few minutes with IDS. Needs an ETIS log in or means of getting a code to sort the PATS.
Agree with RichieST -Would have thought most dealers with IDS would charge an hour at most to do it.
Look for a local mobile locksmith who has the kit to do it.
Old May 4, 2012 | 11:11 PM
GVK.'s Avatar
GVK.
IDS starts at £2800 up to dealer level kit £8k
http://www.ford-ids.com/uk/start_gbr.html
cossie brad
Sep 29, 2015 02:38 PM
Sep 28, 2015 10:05 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
grishenko45
Sep 9, 2015 12:58 PM
