Escort RS1600i This forum is for all things about the Escort RS1600i
RS1600i inlet differences over XR3i MFi
Old May 4, 2012 | 03:21 PM
JasonXR2Racer's Avatar
JasonXR2Racer
Default RS1600i inlet differences over XR3i MFi
Anyone know what the differences in the Rs1600i inlet plenum over the XR3i MFi
I know what externally but were the internals opened up slighty?
they also have the 4 bolt throttle housing same as early XR3i's
I'm thinkig of uprating my MFi Xr3i racecar engine wise and want to keep the standard MFi set up if possible
or it will be Jenvey time
Cheers!
Old May 5, 2012 | 05:57 PM
XR2's Avatar
XR2
The casting was totally different. longer trumpets and as it seems a slightly smaller plenum.
Old May 6, 2012 | 08:03 PM
JasonXR2Racer
just thinking it must have had some slight performance differences over the Xr3i inlet?
Old May 6, 2012 | 08:24 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
much bigger throttle body too, i bought one just to see about fitting it to an rs turbo once
still in my shed
Old May 6, 2012 | 08:25 PM
1.9 xr2 on 40's
st170 breaking
also the tb sits at a different angle
Old May 6, 2012 | 10:11 PM
XR2's Avatar
XR2
That's just because the RS1600i was developed for LHD vehicles. Brake servo sits a lot lower so for the XR3i it must have been altered to run the induction hose behind the servo.
A friend of mine (with a master degree in automotive engineering and several years of engine development and motorsport experience) told me it's better for engine response (because of the 2.8i throttle body) and for low rev torque.
Old May 11, 2012 | 07:11 PM
JasonXR2Racer
Smile
Cheers Guys
I might try and get hold of one then
Old May 11, 2012 | 07:16 PM
1.9 xr2 on 40's
st170 breaking
Originally Posted by JasonXR2Racer
Cheers Guys
bid me, can come with the tb too altho its in bits and i was looking to have it machined to take the rst bits
Old May 11, 2012 | 07:27 PM
stevo123's Avatar
stevo123
Don't know if you are aware but the throttle body off a v6 2.8 capri will fit the 3i plenum perfectly. The plenum will need opening up to match the throttle body though of course
Old May 11, 2012 | 11:41 PM
XR2's Avatar
XR2
No it won't. 3i has a triangular shape, RS1600i a rectangular. MK3 XR3i ones came with an adaptor to make a rectangular tb fit. MK4 XR3is had triangular tbs. And after all... the standard RS1600i tb is as big as the 2.8i one.
Old May 15, 2012 | 01:49 PM
JasonXR2Racer
yeah i would need the Mk3 XR3i inlet as my mate fitted one to his racecar when we did a tintop race with a 2.8i
I know someone with a complete Rs 1600i inlet with throttle body
Old May 15, 2012 | 01:50 PM
JasonXR2Racer
i'd rather you say how much your after
already been offered one thats complete with injector sadwich too
wowk
Mar 30, 2021 07:49 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
Benleys
Escort Range
Sep 28, 2015 01:56 PM
