2wd gearbox and diff oil
Old May 3, 2012 | 03:42 PM
jimhc's Avatar
jimhc
big jc
Default 2wd gearbox and diff oil
I have brand new bottle of miller motorsport crx 75w90 fully synthetic gear oil would that be ok to use either the gearbox or diff of my 2wd cossie?
Old May 3, 2012 | 04:01 PM
flannigan's Avatar
flannigan
In the diff yes not the gearbox as it uses ATF dextron2
Old May 3, 2012 | 05:32 PM
WongRS's Avatar
WongRS
i was told to run 75w 90 in my T5? And i run ep80 90 in my diff, as it's all i could find in the garage!
Old May 3, 2012 | 06:45 PM
gibbo frst's Avatar
gibbo frst
i ran 75/90 fully synth in my t5 and std diff and never had a problem.. quitened the box right down as used to get noisy with the red water it had in before.. was recomended by bara..
Old May 3, 2012 | 07:23 PM
TieMyShoe's Avatar
TieMyShoe
your T5 is a world class T5. The WC T5 should not be running gear oil. It is to thick and will in time damage the syncros. ATF is the correct fluid for a WC T5 and gear oil for a NON WC T5. You will find if you swap out the gear oil for ATF the trans will shift much smoother.
Old May 3, 2012 | 08:31 PM
gibbo frst's Avatar
gibbo frst
mine was a little notchy from cold but once warmed up a little was perfect..
i had a new box fitted years ago by a1 rallysport and they used gear oil and not atf.. bara rebuilds them and recomended it to me and never had a problem with syncros... just stripping 3rd gear but doubt that was the oild fault..
this was on the normal cosworth t5 box
Old May 3, 2012 | 08:35 PM
WongRS's Avatar
WongRS
Normal cossie box is a WC i believe, i was recommended 75w-90 as i said, but my box was scrap anyway, it turned out.
Old May 3, 2012 | 09:12 PM
jimhc's Avatar
jimhc
big jc
this hasnt helped any haha
Old May 3, 2012 | 09:21 PM
WongRS's Avatar
WongRS
Basically, you can't go wrong with ATF, really. If your desperate. I've heard of loads of people going for 75w 90 though.
Old May 3, 2012 | 09:27 PM
jimhc's Avatar
jimhc
big jc
im not desperate i just found a unopened gallon of 75w90 and i wondered if i could use that in the diff or box so il use it in the diff instead of trying to sell it
Old May 3, 2012 | 09:28 PM
DAN400's Avatar
DAN400
i used to run mobil 75/90 in my box, then it started sticking in 4th,
it had broken and bent some sort of guide things, cant remember now what they were called,
the man that sorted it said it was most likely down to the oil i was running and to run the genuine ford mtx 75/90 oil as its different from other 75/90 oils,
i did as he said , so far so good , feels alot better than before too
gingeRS
Sep 4, 2015 06:29 PM
hopper350
Sep 4, 2015 12:53 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
StephTell
Sep 2, 2015 06:31 PM
FlashRS
13
Aug 31, 2015 06:02 PM
