Braided Teflon Hose Cutting ?
Old May 1, 2012 | 10:24 PM
900ss's Avatar
900ss
RWD Racer
Default Braided Teflon Hose Cutting ?
Anyone tried this?
What's the better way to cut braided teflon oil/fuel hose?
Disc grinder or chisel .. or other ?
Old May 1, 2012 | 11:05 PM
Retro Al's Avatar
Retro Al
RWD IS KING
I wrapped mine with some tape and cut with it with a hacksaw.
Old May 1, 2012 | 11:42 PM
Gav Diamond's Avatar
Gav Diamond
I wrap where I want to cut and use an angle grinder with the thinnest (spelling?) metal cutting disk I could find.
Have tried many ways and non seem to work perfectly but find I get the best results with the above method.
Old May 1, 2012 | 11:46 PM
KnoxyGtt's Avatar
KnoxyGtt
T34 just kicked in Yo
An anle grinder blade, the thinner the better. Dont use a hammer and chissle, there are a few guides on the internet that tell you to use a sharp chissle and hammer through it, if you do it splits the sides of the teflon when it mashes it down before it cuts through it no matter how sharp, hard or fast you hit it.
Old May 2, 2012 | 12:26 AM
NoRubNoDub's Avatar
NoRubNoDub
McGarrity Motorsport
tape it and use a fine hack saw.
Old May 2, 2012 | 06:01 AM
900ss's Avatar
900ss
RWD Racer
Cheers, will go for the disc grinder
Old May 2, 2012 | 06:32 AM
RS500/364's Avatar
RS500/364
Dermal diamond disc !
Old May 2, 2012 | 03:21 PM
focus 4x4's Avatar
focus 4x4
+1 I found this the best way too
Old May 2, 2012 | 03:26 PM
rog's Avatar
rog
Me too! I've heard using a grinder is pretty effective and obviously less time comsuming, you're probably more likely to get a clean cut and less fraying as well.
Old May 2, 2012 | 05:06 PM
rstdave's Avatar
rstdave
+1 on the thin cutting blade with tape wrapped round to try and prevent fraying!
Old May 2, 2012 | 06:03 PM
ST Turbo's Avatar
ST Turbo
A chisel? On a metal braided hose?? Some people should not be let near tools.
Get a cutting disc on a little 4" grinder and tape up where you want to cut and it will come out perfect.
Old May 2, 2012 | 06:47 PM
Luca's Avatar
Luca
Lukesville
Use your teeth - save the chisel!!
If that fails the grinder is the next best option works every time.
Old May 2, 2012 | 09:14 PM
900ss's Avatar
900ss
RWD Racer
What he does ?
http://www.youtube.com/watch?v=dkqO6...eature=related
Old May 2, 2012 | 09:39 PM
MarkTurbo's Avatar
MarkTurbo
I work for Goodridge and its usually cut on a saw with a super sharp thin metal blade. When i have to make lines up away from work i always wrap it with masking tape and use the thinnest cutting disc i can find in an angle grinder as others have said. That is the next best way in my opinion
Although maybe i should do it properly and get a huge great chisel and a big hammer
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
