Cosworth firing problem
Old May 1, 2012 | 11:40 AM
shortie's Avatar
shortie
Default Cosworth firing problem
Cossie engine turning over but not starting no spark
Old May 1, 2012 | 12:08 PM
martysmartie's Avatar
martysmartie
Do you hear the fuel pump when the ignition is switched on?
Martin
Old May 1, 2012 | 12:13 PM
SaphCos4x4_Dan's Avatar
SaphCos4x4_Dan
loves a good ham shank
Crank sensor? Coil? Engine earth?
Old May 1, 2012 | 12:44 PM
xr4x4rs's Avatar
xr4x4rs
have you disconnected anything lately?
chack crank sensor, igntion amps and dizzy
Old May 1, 2012 | 01:31 PM
shortie's Avatar
shortie
Engine has been out but everything was ok when we went to santa pod
Old May 1, 2012 | 01:54 PM
xr4x4rs's Avatar
xr4x4rs
so its just decided not to fire up?
Old May 1, 2012 | 02:07 PM
saph4be's Avatar
saph4be
phase sensor worth checking#
Old May 1, 2012 | 06:16 PM
martysmartie
Like I say you need to confirm whether or not the pump primes, as alot can be told from that.
Martin
Old May 1, 2012 | 06:26 PM
botters's Avatar
botters
competant bodger
bad or wrong connector on crank sensor
Old May 1, 2012 | 06:41 PM
New Shell Dude's Avatar
New Shell Dude
Cosworth firing problem, i use a gallon of petrol and a box of matches.
Old May 1, 2012 | 08:19 PM
shortie's Avatar
shortie
Funny, not
Old May 1, 2012 | 08:23 PM
New Shell Dude
Originally Posted by shortie
Funny, not
Sorry i couldn't help it. I hope you get it sorted.
Old May 1, 2012 | 08:40 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Crank and phase sensor connections on round the wrong way ?
Steve
Old May 2, 2012 | 07:32 AM
shortie's Avatar
shortie
No probs m8
Old May 2, 2012 | 10:55 AM
shortie's Avatar
shortie
Changed phase & crank sensor still not firing up & fuel pump not priming so it could be alarm clifford concept 300 fitted on car
Old May 2, 2012 | 12:20 PM
martysmartie
It's impossible to say as it depends on which circuits are immobilized, but it will be either a ECU problem, no power etc or the CPS signal is not being received, bad wiring etc.
The easiest way to check is to see if the immobilizer LED is extinguishing when the ignition is on? If so then it's working, by indication at least.
That is why I asked first as it's pointless aimlessly changing sensors seen as no one would be able to tell from the initial information what was wrong!
Are all four lugs intact on the crank pulley as well?
Martin
Old May 2, 2012 | 01:22 PM
shortie's Avatar
shortie
Yes m8 my mate is on his way over with a low loader to take it to an auto electrician
Old May 3, 2012 | 12:23 PM
shortie's Avatar
shortie
Found out what the problem is the fuse board is fooked
manuel boeckx
13
Oct 3, 2015 02:29 PM
CLIVE
Oct 2, 2015 12:58 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Aug 14, 2015 07:29 AM
Sjieter
Aug 5, 2015 09:47 PM
