4x4 saff engine removal
Is it possible to take out a 4x4 cossie engine and leave the sump in place to basically undo all sump bolts first the lift out engine?
ah ok i'll bear that in mind. If i cut the pick up pipe can i replace it with a 2wd one as the engine will be having a 2wd sump put on it or will i have to use a 2wd pump as well.
Thanks for the reply.
Phil
Phil
JoeyBoyden
04-01-2024 02:36 PM
mrmann
20-08-2015 11:24 PM
track.focus'd
12-08-2015 05:53 PM
lockie
31-07-2015 10:03 PM
