Escort and saph rear prop differences?
Old Apr 30, 2012 | 10:30 PM
rog's Avatar
rog
Default Escort and saph rear prop differences?
What's the difference between a saph rear prop and an escos rear prop?
Old Apr 30, 2012 | 10:48 PM
xr4x4rs's Avatar
xr4x4rs
escos is shorter rear section
the front section has the thin rubber doughnt
safs use large rubber doughnut and are longer rear section
Old May 1, 2012 | 08:07 AM
rog's Avatar
rog
Ok thanks, the box was recently swapped on my saph and the mechanic said he thought the two pieces (splined section) should have mated up further, I think the gearbox might be off an escos, but I checked it against the old box and another one I have and the output shaft to the rear prop all look the same length, I was informed the escos one is different to the saph (with the escos flange being shorter?)
Old May 1, 2012 | 10:46 AM
xr4x4rs's Avatar
xr4x4rs
the escos out put shaft is longer, uses a different 3 prong thing, and use shorter bolts
the actual front part of the props are the same just the doughnuts are different
Old May 1, 2012 | 09:59 PM
Iain Mac's Avatar
Iain Mac
Not sure that's right. The thick donut has a bush for the spigots on the prop and output shafts, but the thin donut allows the shaft to go through and slip over the output shaft.
Vincereese
Jun 1, 2023 09:14 AM
borboyous
Aug 22, 2015 11:17 AM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Bosch
Aug 4, 2015 05:14 PM
