HELP Please - Weird Electrical Problem on 4x4 Saph Cos
Good evening all
My 4x4 Saph Cossie has developed a weird electrical problem and I am hoping someone may be able to help out with some ideas...
Basically when I'm driving along and put the indicators on, or touch the brake, the power to the stereo cuts for a split second, and the rev counter flickers or doesnt read true engine revs (until indicators are cancelled). Only developed this problem on the way to Central Meet at the Pod a few weeks back.
Someone suggested it is likely to be an earthing problem so Ive cleaned the main earths under the bonnet, and also behind the dash and in the footwells but this hasn't made any difference.
If anybody is able to shed any light on this for me I'd be really grateful
indicators and brakes means the most likely culprit is the wiring loom that goes form the reverse light switch and up along the gearbox to the bulkhead behind the head
unplug the 8 pin multi plug and see if it solves the issue, there should only be 3 wires in the plug though
I bet it's an aftermarket head unit?
I would trace back the radio wire ground, I don't know if the instrument cluster etc shares the same ground, probably as it's in close proximity of each other, if so it's worth checking/cleaning this, it's most likely corroded.
Martin
Martin
Thanks again for the suggestions guys, its much appreciated
OK slight update - in addition to cleaning the earths under the bonnet (behind each headlight, battery tray, inlet, behind battery, bonnet) we've cleaned the ones behind the dash clocks that are mounted to the steering column support plus those in the the side of the footwells and the gearbox to chassis earth.
Looked for some in the book for the rear lights (as someone suggested this could be a fault) but they are earthed through the loom that heads towards the front of the car. Cleaned the terminals just in case though.
Suspect the stereo earths are those on the steering column support so thats them cleaned, will unplug the reverse light switch and try that. The headunit uses the original loom so will unplug that aswell and see if the fault disapears.
With the engine running, the moment you put indicators on the dash lights go dim and pulse in time with the indicators. When you touch the brake pedal they go dim as well and return to normal again almost straight away (even with foot still on brake). The rev counter also flickers either when brake pedal is initially applied or when indicators are turned on. The hazards however have no effect on either, nor do the wipers?
Any other ideas?
Any other ideas?
Forgot to mention - couldnt get the headunit to loose power up either by touching the brake or putting indicators on so maybe cured that... either that or just decided to work tonight?
Going to get meter and test the wires as majority of earths are now clean and it hasn't made any difference but there could obviously be a break somewhere. Removed the headunit to see if this was causing any problems and this also made no difference so think I can rule that out too.
I need to source a wiring diagram as my workshop manual doesn’t have that in it. Dont suppose anybody has a .pdf they can e mail me in return for my eternal gratitude??
I've got the kind of problem with mine but its the battery light dimly glowing when I have the lights on. I've cleaned and checked the earths and no difference. I did find high resistance on the earth of the drivers rear light which temp earthed out but still had the problem I am looking into that but want to find the bat light problem and hope to stumble across the other one at the same time.
I had this problem with mine (didn't turn off) even with the keys out.. Turned out that the ABS wiring loom had got hot and melted where it goes through the bulkhead near the ECU.. Pulled some slack out into the engine bay and seperated the wires (4/5 had melted together) and heat shrinked them. Problem went away
Kev - Have you tried taking the fuse out of the box for the interior power? (think it's 28) as the lights/dash etc won't run on the same relay.
maybe not explained 100% but i had this up till a while back does you battery drain !
I think the battery does drain, but the car is only used now and again so it is usually plugged into a CTEK.
I haven't changed any ABS wiring, but this sounds like it could be a job for a sparky.
The pump switches off when the system is at the correct pressure, the same as it does when driving etc, if you were to push the pedal a few times you will hear it activate.
Martin
Also to OP, it may be worth looking at the battery terminals etc to see if someone has dangerously just run a direct live, in either that or back of ignition etc!
Martin
DixieTheKid
Jul 23, 2023 10:16 AM
jdsjojo
Aug 30, 2015 07:48 PM
