Who's running a RWD diff in a 4x4?
Old Apr 30, 2012 | 03:12 PM
rog's Avatar
rog
Default Who's running a RWD diff in a 4x4?
I'm aware you need to cut the diff casing or modify the beam, thats cool enough, but the output flanges are different.
So.... do i need the whole driveshaft including the outer cv as well or can i mate the 2wd inner cv/flange to the rest of the 4x4 shaft?
Old Apr 30, 2012 | 03:24 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Can't help with your Q's but Won't the diff ratio mean the rear wheels will be turning faster/slower than the front?
Old Apr 30, 2012 | 03:29 PM
rog's Avatar
rog
Not an issue as the ratios are about .01 out so it's almost irrelevant IIRC.
Old Apr 30, 2012 | 03:32 PM
daz1968's Avatar
daz1968
I would think easiest option is to fit a 2wd rear beam and 2 wd shafts, best sticking the 4wd rear brakes on though as they are vented.
Old Apr 30, 2012 | 03:44 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Change the driveshafts and drive flanges on the hubs for 2wd stuff and it'll be fine.
Old Apr 30, 2012 | 07:06 PM
rog's Avatar
rog
I'm not changing the hubs, the offset will end up being all be wrong, hence why I just want to change as little as possible.
Old Apr 30, 2012 | 07:16 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
just change to the 7.5in rear beam and diff and use 4x4 output flanges
Job jobbed
Old Apr 30, 2012 | 07:20 PM
WongRS's Avatar
WongRS
i've just put 7.5 in the back of mine, albeit now rwd, but its still 4x4 hubs and everything,
you need....
2wd diff
2wd beam
2wd shafts
2wd output joints,
it all then bolts up fine, the 2wd outputs bolt into the 4x4 hubs.
Old Apr 30, 2012 | 10:14 PM
rog's Avatar
rog
I was talking to someone earlier who suggested I swap the ouput flanges but I didn't know if that was possible, so are you saying it is?
Wong, what is an "output joint"
If you're saying that complete 2WD shaft will go into 4x4 rear hub then all I will need is the diff and both shafts.
Old Apr 30, 2012 | 10:53 PM
WongRS's Avatar
WongRS
I Meant output flange, couldn't think of the word!
Yeah, complete 2wd shafts, diff and beam.
Old Apr 30, 2012 | 11:31 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Easiest way is stick the entire 2wd beam in, as an assembly.
Next easiest way is to transfer the diff with the entire driveshafts, inc stubs as they go straight into the 4x4 rear hubs.
jason_nike
Aug 18, 2019 10:53 AM
Chas
Sep 21, 2015 08:57 PM
FlashRS
Sep 14, 2015 12:36 PM
Marc sierra
12
Aug 30, 2015 10:38 AM
Shows & Track Days
Aug 15, 2015 06:25 AM
