Heater problems
Having problems with the heaters in my xr3i. They put out good hot air within a few minutes usually but all of a sudden have stopped getting hot.
Driving for about 12 miles today and they suddenly went hot then cold again! Don't think its the matrix as they are usually really warm.
I think its the thermostat alothough thats only a year old. Also noticed fans are on when engine isnt really that hot.
Am i right in thinking its the thermostat???
Could be the thermostat, the easy way to confirm is to look and see what the temperature gauge is telling you, if the stat is stuck open it will run too cool.
Although for the fans to be activating would generally mean it is doing the opposite, i.e. overheating, thus your would have heating!
Don't just assume it's one single problem, it may be to completely different problems.
Martin
Martin
Well for a week or so the gauge stayed really low and now it reads just under halfway ish which i take as normal.
Heaters seem to be cold then hot etc
Dont think its overheating think its the thermostsat playng up so will change this and go from there.
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
mk1focus
Ford Fiesta
Sep 24, 2015 06:19 PM
