who's got coilovers?
Old Apr 25, 2012 | 01:41 PM
beaver rs 88's Avatar
beaver rs 88
in the garage
Default who's got coilovers?
Guys who's got coilovers on their series 2? Need abit of help as I've got some gaz ones to fit and can't seem to work out how the rears fit into the turret. Do you use the bush from the original damper sleeve on top of the top hat of the coilover or just put the metal cup on the top hat then fit it up into the strut? Any help appreciated. Nick.
Old Apr 25, 2012 | 03:35 PM
RSandy's Avatar
RSandy
i fitted mine with the cup on top of the top hat, otherwise it wont seat right in the bush
i hated the fitment of mine, plus the top hats were too tall so i couldnt get the car low. i had custom shoter top hats machined, that let me go low, but the fitment was still shocking, and my wheels rubbed the coilover spring, so i soon flogged my rear coilovers on and just stuck with the fronts
spose it depends how low u wana go, what size wheels u run, and how much the bad fitment annoys u lol
Old Apr 25, 2012 | 06:17 PM
beaver rs 88
in the garage
I'm gonna be running 205 40 16 tyres and I'm not bothered about going silly low just 25-30mm
Old Apr 25, 2012 | 11:03 PM
beaver rs 88
in the garage
Anyone else?
Old Apr 25, 2012 | 11:08 PM
7sean7m7's Avatar
7sean7m7
Im sure i read you had to get a kit to put them on seperate like the original strut and spring.. But then they are still adjustable with the damping bump and rebound.
Old Apr 26, 2012 | 11:41 AM
Rogeyboy's Avatar
Rogeyboy
Don't you have to weld the rear turret tops as they are not load taking from the factory... Ive heard afew people putting their coilovers through the tops over hard bumps!
Old Apr 26, 2012 | 12:21 PM
beaver rs 88
in the garage
I'm gonna be running a rear strut brace which is more than enough but its just the way they fit that puzzles me.
Old Apr 26, 2012 | 06:09 PM
turbotrev's Avatar
turbotrev
Anyone got any pics of these fitted?
Ive heard various stories over the years about people getting grief when fitting these?
Was looking at getting some in the future but depends if its worth the hassle???
Cheers Paul
Old Apr 26, 2012 | 06:34 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yes you do.
Thats not going to help at all mate.
Old Apr 26, 2012 | 06:47 PM
luke19790_3's Avatar
luke19790_3
you don't need to weld the rear. sure there was a thread on this somewhere
Old Apr 26, 2012 | 06:51 PM
luke19790_3
have a look at the comments from nuts r us
https://passionford.com/forum/ford-e...-the-rear.html
Old Apr 26, 2012 | 07:36 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Thats very interesting as I have read of people having them break through?!
Old Apr 26, 2012 | 10:06 PM
beaver rs 88
in the garage
I've been told off a few people on here that the welding isn't required and they had been running them for years.
Old Apr 27, 2012 | 10:08 AM
Rogeyboy's Avatar
Rogeyboy
Quote from that link...
Problems will arise however if people fit coilovers then still expect to carry 4 up in the car over speed bumps etc. Coil overs are not designed to carry weight at the top !!
There you go, i wouldnt chance it personally as i use my car to transport 3/4people around quite alot.
Old Apr 27, 2012 | 05:54 PM
beaver rs 88
in the garage
Hi rogeyboy I don't plan on having passengers as its gonna be more track than road based cheers mate.
Old Apr 27, 2012 | 07:30 PM
jonny s2's Avatar
jonny s2
rear turrets dont need welding
Old Apr 27, 2012 | 10:39 PM
project rs's Avatar
project rs
mines had 5 in it and been full in boot too several times and never had a problem with them and had some hard abuse full loaded
Old Apr 28, 2012 | 02:06 PM
Rogeyboy's Avatar
Rogeyboy
Maybe the people that cracked or split the rear turrets were unlucky then... Or their car were rotten in that area!?
Old May 14, 2012 | 06:58 PM
simsytall's Avatar
simsytall
series 1
to be honest i've heard youdo and don't argument i run them abuse my car carry 4 people to and from shows etc etc and don't have issue's as roger says unlucky or the cars not 100%rust free
jessie_rs
62
Aug 6, 2019 09:27 PM
mk1turboestate
Dec 2, 2015 08:31 PM
S3an
Sep 26, 2015 11:39 PM
CrOwSoN15
Sep 24, 2015 01:36 PM
S3an
13
Sep 13, 2015 10:01 AM
