efi on zetec bottom end help
Old Apr 25, 2012 | 10:58 AM
xr4x4rs's Avatar
xr4x4rs
Default efi on zetec bottom end help
a friend of mine has a mk3 escort with zetec bottom end running frst management
the problem he is having is he carnt rev past 4k
im thinking it has the wrong flywheel on as it has a zetec one or are the pick up points on the zetec and frst the same?
if not what would stop it reving past 4k, everything has been changed and double checked and i can only see it being flywheel now
but want to make sure before i have to take gearbox off and swap everythig over
Old Apr 26, 2012 | 01:43 PM
xr4x4rs's Avatar
xr4x4rs
anyone?
Old Apr 26, 2012 | 03:01 PM
Karlos G's Avatar
Karlos G
Balls Deep!
If it's running a BC gearbox then it will have a CVH flywheel, even if it's not the CPS is in the same place so no it's not the flywheel.
What exactly do you mean by won't rev past 4k... Is it just holding back, is it like a rev limiter?! Bit more info please mate.
Old Apr 26, 2012 | 04:45 PM
xr4x4rs's Avatar
xr4x4rs
its running a std rst gearbox with a zetec flywheel
as far asi know its like hitting the rev limiter just isnt going past 4k, only going by what ive been told im afraid
RSmark84
Sep 13, 2015 01:29 PM
BRAM
Sep 8, 2015 07:11 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
bigryrs
Sep 7, 2015 06:45 PM
