Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
1.6 zetec conversion
Old Apr 23, 2012 | 06:15 PM
cgray's Avatar
cgray
Default 1.6 zetec conversion
Hi I have a mk1 1.6 zetec focus. I am going to put a 1.4 head on it. 1.8 valves would be best are they the same length as 1.6? Any help is welcome thanks
Old Apr 23, 2012 | 09:21 PM
Straight_4_N/a's Avatar
Straight_4_N/a
First off why fit a 1.4 head its got smaller valves (please dont say is to higher your comp ratio as you can get your 1.6 head skimmed to the same)
and i dont think the zetec-e valves will even fit in the zetec-se head.
if i was you either fit a 1.7 engine or fit a 2.0 engine both go easy into the focus and you can do it your self for less than £400 with 30bhp gain. (2.0s abit more straight forward as you dont have to mess around with the wiring as much)
Old Apr 23, 2012 | 09:38 PM
luke19790_3's Avatar
luke19790_3
why???
Old Apr 23, 2012 | 09:39 PM
cgray's Avatar
cgray
I know you can skim the 1.6 although I think the 1.4 would work better. I can get one for about £50 as well. Do you know if the valves are the same length?
Old Apr 23, 2012 | 09:40 PM
cgray's Avatar
cgray
Originally Posted by luke19790_3
why???
Why what?
Old Apr 23, 2012 | 09:57 PM
Straight_4_N/a
not really you can skim the 1.6 head right down to the limit just before it hits the valves 1.4 wont be any better.
where you going to? it only costs £40 to have the head skimmed.
mite be the same length but thay mite not sit the same way in the head you'll need to get one of each and check if there the same or not (just with bigger ends).
Old Apr 23, 2012 | 10:01 PM
nickscunny's Avatar
nickscunny
just drop a 1.8 engine in... job done!
Old Jun 7, 2012 | 12:53 AM
Pucci1's Avatar
Pucci1
Hey guys anyone got a link in a detailed guide for a focus 1.6-2.0 zetec conversion mk1 thanks
Old Jun 12, 2012 | 02:16 PM
JPW01's Avatar
JPW01
The 1.4 head surely has smaller ports valves than the 1.8 head? Sorry but I think your going on a time wasting and money wasting way. Get your 1.6 head skimmed, and polished and ported. put some lairy cams in and you will feel a big difference. or drop a 1.8 or 2.0 engine into it. Personnally after more than one person has advised this to you I would seriously think that they are offering you good sound advice.
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
