Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
Garage floor / surfaces, what have you got ?
Old Apr 23, 2012 | 04:21 PM
trek's Avatar
trek
Default Garage floor / surfaces, what have you got ?
As the title, what coatings, coverings do you have and how well does it work ?
I've just built a new garage and I want a easy to clean, dust free surface that won't wear as the car is driven in a out.
I've used cheaper garage floor paints in previous garages and its not lasted too long. Currently considering 2 part epoxys, rubber floor tiles or ceramic tiles.
Ideally want something not too expensive, but willing to pay the extra for something that will last
So any advice / recommendations ?
Old Apr 23, 2012 | 04:45 PM
Rs-Adz's Avatar
Rs-Adz
I painted mine in the cheap garage floor paint on ebay and it peels off when i drive the car in there so also interested in knowing??
Old Apr 26, 2012 | 08:11 PM
New Shell Dude's Avatar
New Shell Dude
Heated floor with ceramic tiles. I often get a uncontrollable urge to just lie down on it.
Old Apr 26, 2012 | 09:31 PM
sicosnutter's Avatar
sicosnutter
thougt about getting some of this for mine
http://www.ebay.co.uk/itm/3602832467...84.m1423.l2649
Old Apr 27, 2012 | 03:22 PM
whizzisat114's Avatar
whizzisat114
Ive used johnsons floor paint
prepared the floor by vacuming then mopping
two coats of p v a mixed with water and it seems very easy to keep clean and hard wearing
Old Apr 28, 2012 | 08:09 AM
gus's Avatar
gus
how big is your garage and what did it cost to? also to run?
Old Apr 29, 2012 | 07:31 PM
beefyecosse's Avatar
beefyecosse
costco are doing a roll of vinyl garage floor covering just now for Ł120 a roll
Old Apr 29, 2012 | 07:36 PM
gouch1's Avatar
gouch1
i painted mine with industrial floor paint it has never peeled easy to lean ect but the trolley jack and ramps now slide and when its wet im like torvill and dean
Old Apr 29, 2012 | 07:41 PM
RichieST's Avatar
RichieST
Mate of mine put the rubber garage flooring down, was great until he jacked his car up and the jack went straight through!
Old Apr 29, 2012 | 08:52 PM
sicosnutter
got a couple pieces of chequer plate for that,and four squares for axle stands.
Last edited by sicosnutter; Apr 29, 2012 at 08:53 PM. Reason: spelling mistake doh!!
Old Jun 2, 2012 | 07:46 PM
Gadget's Avatar
Gadget
Spanner monkey
I've got normal concrete floor, then floor painted. Then got carpet down. Just get the hoover out and its clean again!
Old Oct 3, 2012 | 09:12 PM
Pob's Avatar
Pob
I've a thick rubber matting down on mine. It's heavy and durable. Plus, when your under the car, or kneeling down to jack it up. Its ok on your joints.
Old Oct 9, 2012 | 09:55 PM
jerkyboy18's Avatar
jerkyboy18
Old Oct 12, 2012 | 05:09 PM
wetandwindy2's Avatar
wetandwindy2
Originally Posted by jerkyboy18
i know a couple o guys with this stuff its a bit pricey but apparntly worth it
Old Oct 15, 2012 | 09:00 AM
bigryrs's Avatar
bigryrs
RSHoleinator
Where can I get it from?
Old Oct 15, 2012 | 11:41 AM
jerkyboy18's Avatar
jerkyboy18
R-tek manufacturing Armagh n, Ireland there doing special offer at the minute for black and grey Ł18 square metre
Old Oct 15, 2012 | 11:15 PM
wetandwindy2
cannt remember exactly but am sure i saw an ad in one of the ford magazines retro performance or one of them or try googling it something might come up
Old Oct 15, 2012 | 11:17 PM
wetandwindy2
i googled in garage floor tiles and amongst others this came up but theres afew companies out there that can supply
http://0.r.msn.com/?ld=4vZqIOvdxuvdf...g_tADx3ChvQEjM
Old Oct 16, 2012 | 04:13 AM
NEIL A's Avatar
NEIL A
I got mine off of ebay think it worked out around 400 pounds to do my garage. Since then they have been down for 2 years, in that time they have had a hard life but still come up fairly well with a good scrub. If you use your garage for storing a car there great if you use it for working on them then paints the better option.
Old Oct 23, 2012 | 06:34 PM
bigryrs's Avatar
bigryrs
RSHoleinator
That's a cracking garage mate! I've painted my floor with industrial stuff that BMW/specialist cars use on there workshop floors! When I move house i'l probably look into a similar flooring to yours as I love the neat look and black with White
Old Feb 25, 2013 | 11:11 AM
romfordrst88's Avatar
romfordrst88
I'm using a floor paint called flow-Crete 2 pack, you shoot the floor with small metal balls then use a big magnet to pick it up and also hover the area then lay a glue down wich then you spread sand on then once its gone off sweep and hover it then add your colour on top it's used in big car parks.
Old Feb 27, 2013 | 10:31 PM
stevegtuk's Avatar
stevegtuk
i used standard floor paint and it peeled off like all the rest, then I went to wickes and got garage floor paint, after a year nothing has peeled or rubbed off.
gambo08
Feb 4, 2016 10:49 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Orion_Gav
Sep 29, 2015 04:50 PM
rsguy
44
Sep 29, 2015 03:29 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
