How to get rid of flat spots? (tyres)
Old Apr 23, 2012 | 10:34 AM
user 7082039239's Avatar
user 7082039239
Don't mention ze Vor
Default How to get rid of flat spots? (tyres)
Had my MR2 Turbo stored during winter. I even put styrofoam blocks under the wheels. However the ones I put under the rear wheels were quite hard and didnt really flex.
Now I've got a vibration from the rear at 50 - 65 mph. Under and over that it's absolutely fine. Can't tell if the problem existed last season since one of my wheels was buckled. Car is on 100% straight and balanced wheels now.
Any ideas how to get rid of the problem without buying new tyres?
Last edited by user 7082039239; Apr 23, 2012 at 10:35 AM. Reason: 2500 posts - YAY!
Old Apr 23, 2012 | 01:52 PM
alo's Avatar
alo
Rolling burn out?
Old Apr 23, 2012 | 02:30 PM
Robs Frst's Avatar
Robs Frst
Never heard of getting rid of flat spots of tyres.
Think you will just have to replace them
Old Apr 23, 2012 | 02:34 PM
Mk4 Lew's Avatar
Mk4 Lew
Originally Posted by alo
Rolling burn out?
sounds fun
Old Apr 23, 2012 | 03:03 PM
tommytwotanks's Avatar
tommytwotanks
fit the spare wheel, and see if you still have the problem
Old Apr 23, 2012 | 06:32 PM
Dont store the car and use it lol.Can you not out the car on axle stands when your not using it.
Old Apr 23, 2012 | 06:46 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
i expect its the metal banding thats bent so i think you may be buggered but id would put 70psi in and drive them til warm and see if it helps
i dont knows if thats bad but ill try anything once
Old Apr 24, 2012 | 12:35 AM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
check the tyres rated maximum pressure before you try and put loads of air in it
Old Apr 24, 2012 | 07:00 PM
stevieturbo's Avatar
stevieturbo
C**t
double post
stevieturbo
C**t
How many years was it stored for ? Cant say Ive ever had it happen a car even if sitting parked up for well over a year.
And clearly if the wheels/tyres balanced fine, the wheels/tyres are not the problem. If if the tyres had flat spots ( which actually only occurs after a severe lock up ) the problem would be there at all speeds.
They dont suddenly go from round to flat then round again.
Swap wheels back to front and see if it moves. But it usually takes a huge issue on rear tyres for it to actually be felt.
Old Apr 26, 2012 | 07:33 AM
user 7082039239
Hi there,
After driving again, I think it's actually not the tyres but the driveshafts. Possibly even an engine mount as I've discovered that it only occurs under high load at relatively low rpm.
Thanks for the advice anyways!
tankybaby66
Feb 6, 2016 02:24 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Alloy wheels and ICE for sale
Sep 28, 2015 06:19 PM
