Sierra SR20DET drift/track car
Old Apr 22, 2012 | 09:01 PM
gejm10's Avatar
gejm10
Default Sierra SR20DET drift/track car
Sierra SR20DET drift/track car for sale,
Engine,
Nissan SR20DET and gear box short shifter and new clutch fitted
Head, Polished & ported, valve re-seated and 3 angle seats, new valves, rocker arm stoppers head skimmed,
Block, Wossner H-beam rods ARP bolts and pistons oversized, crank & flywheel balanced, new oil and water pump, new big end bearing, new drive chain, ARP head bolts, 1.6mm HKS steel head gasket, intake manifold internal polished , stainless steel exhaust manifold internal polished, 3” exhaust, turbo is g28 garrett turbo, had new bearing fitted
16 row oil cooler ,modified sump and pick up pipe. bosch 044 fuel pump, New fuel pipes fitted, fuel regulator,
Car
5 door ford sierra K reg, full welded in roll cage, seam welded fully adjustable AVO GTX suspension kit, adjustable compression struts and TCAs, vented disc brakes, new brake line, line lock, adjustable bias valve, hydraulic handbrake, hydraulic clutch fitted, stronger prop shaft made by prop tech, welded diff, Stack's Air/Fuel (Lambda) Gauge, raceteck oil temp & pressure gauges, acewell speedometer.
car has only done just over 600 miles since rebuilt
Build can be seen her http://www.driftworks.com/forum/drif...ierra-s14.html
£4500ono
Any questions please feel free to ask ask
Thanks gaz
Old Apr 22, 2012 | 09:51 PM
RST's Avatar
RST
Looks like alot of fun good luck with sale
Old Apr 25, 2012 | 08:30 AM
vaughant's Avatar
vaughant
You should mention it's a turbo in the ad as the SR20 could be a non-turbo as well.
I think it's SR20DET for the turbo version?
Limitless tuning as well.
Cool motor.
Old Apr 25, 2012 | 03:24 PM
I bet its a fun car to drive.Looks like a clean shell too.
Old Apr 25, 2012 | 05:51 PM
Garethw1986's Avatar
Garethw1986
i like that, looks great fun and diffrent,glws
Old Apr 25, 2012 | 07:41 PM
gejm10's Avatar
gejm10
Cool motor.
thanks did not pay any attention to mentioning its SR20DET.
only thing left that I did not do was new cams, adjustable cam gears and 555 injectors, then just remapping
should to it up to about 400-500bhp
was going to this when it got some more miles on the clock, just built it for Strength and reliability to start with.
Old Apr 25, 2012 | 07:50 PM
gejm10's Avatar
gejm10
was lots of fun to drive only which i not got to get rid, only reason its up for sale is money.
shell is in good condition some small bits of rust on there now as its been out side in all weather for 2 years with a cover over it, as i could not keep my lock up going.
Old May 20, 2012 | 07:28 PM
gejm10's Avatar
gejm10
bump!!
Old Nov 30, 2012 | 07:29 PM
gejm10's Avatar
gejm10
bump!
£3500ono
Old Mar 10, 2013 | 08:46 PM
gejm10's Avatar
gejm10
bump £3000
Old Mar 10, 2013 | 09:07 PM
doga-ot's Avatar
doga-ot
Well worth 3k shame its not a saph or 3dr be alot more fun. Good luck bud
Old Mar 10, 2013 | 09:16 PM
theburns1's Avatar
theburns1
cannock is a race track
Location
Old Mar 11, 2013 | 06:36 AM
Paynee's Avatar
Paynee
Originally Posted by theburns1
Location
Been reading the build thread on DW, hes in Dudley, Birmingham way. Impressive build the pictures in this thread do not do it justice after reading the build thread.
Is it still for sale?
Old Mar 13, 2013 | 11:43 AM
gejm10's Avatar
gejm10
Location
west Midlands, Dudley
Old Mar 16, 2013 | 09:22 PM
gejm10's Avatar
gejm10
bump!!
Old Mar 21, 2013 | 08:30 PM
gejm10's Avatar
gejm10
bump!!
Old Apr 7, 2013 | 08:19 PM
gejm10's Avatar
gejm10
bump!!
Old Apr 7, 2013 | 08:22 PM
doga-ot's Avatar
doga-ot
I cannot believe this is still up would of thought someone would of snapped it up well worth the money, that engine set up be great in a saph or 3dr
Old Apr 8, 2013 | 06:58 PM
gejm10's Avatar
gejm10
you could easily swap this into another sierra as all the mounts for the engine and gearbox are off the original. Bit of wiring may be needed and a small cut for the gear lever to come through.
Old May 5, 2013 | 02:29 PM
gejm10's Avatar
gejm10
bump!!
Old Dec 27, 2013 | 04:22 PM
gejm10's Avatar
gejm10
bump! £3000
Old Dec 27, 2013 | 04:53 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
This seriously hasn't sold?
Old Dec 27, 2013 | 05:05 PM
gejm10's Avatar
gejm10
took off sale, was going to keep it but need to get rid of it now :-(
Old Dec 27, 2013 | 10:42 PM
lukeytheduke's Avatar
lukeytheduke
Surely the turbo won't do 400-500bhp????or did I read it wrong??
Old Dec 28, 2013 | 01:19 AM
wattie's Avatar
wattie
Worth 3k for the rebuilt engine plus box alone , surprised noones bought this yet
Old Dec 28, 2013 | 09:44 PM
gejm10's Avatar
gejm10
this is what i was told at the time but iv been doing some research on it should be able to get around 300bhp with out cams, with a bigger turbo 400+
mpilk
Aug 12, 2015 09:40 PM
Vincereese
Aug 11, 2015 08:44 AM
Adam-M
22
Aug 10, 2015 10:46 AM
knight19770
Aug 4, 2015 12:36 PM
Old ford
Jul 31, 2015 06:50 AM
