Stupid question
loves a good ham shank
Can I grind out a slight bit of rot on a chassis leg, treat it and bog/paint the surface to leave it looking original instead of welding a nasty plate over it?
It's not deep enough to require a strengthening plate hence the stupid question
Get a wire bit on a drill/grinder first before you make sure it's actually eating into the metal as lots of surface rust looks really bad but once you get underneath it's solid - i would never stick bog on the underside always cut out
