Any scooby owners in?
Old Apr 20, 2012 | 04:22 PM
saph4be's Avatar
saph4be
Default Any scooby owners in?
I going to look At a 07 plate wrk in morning 2.5 engine is there anything to look for in particular?
And what are the tuning potential ect how far can you take the standard box ect? I know this is a ford site but there's a wealth off knowledge on here thanks!
Old Apr 20, 2012 | 04:59 PM
zippyobrien's Avatar
zippyobrien
Box and diffs are up to 400 bhp no prob.
Look for piston slap on cold start and check the clutch is all ok.
Old Apr 20, 2012 | 05:21 PM
RS Grant's Avatar
RS Grant
Made in Scotland
I'd not want to take a 5-speed, even from a newer 2.5 WRX (which are meant to be a little stronger) anywhere near 400bhp... because on the 2.5 you'll have almost the same, if not more torque as well.
Guy up here tuned his 2.5 WRX to around 350bhp and c370lb/ft and he shat a few gearboxes before he got bored replacing them and went for a 6-speed conversion, which will take far more power than that, with absolutely no issues at all.
Things to check are, tyres (need good rubber... pikey make = pikey owner IMO, so it's not going to have the correct oil/fuel etc), brakes, clutch, service history (cambelt service can be pricey)... and take a look at the intercooler fins, being a top mount, they are known to bend if subjected to constant high speeds... so if there are quite a few bent fins, then it's likely that the car has seen a lot of high speed use.
I'm not sure what you're used to, or comparing the WRX to, but please don't expect it to be electric if it's a standard WRX... PPP's are a little more lively and all the STi upgrades bolt right on, so 350bhp and 370lb/ft is very easy to achieve and will transform the car.
Cheers,
Grant
Old Apr 20, 2012 | 05:40 PM
saph4be's Avatar
saph4be
Cheers,
Grant
I use to own a 380 bhp saff but I not been in anything remotely fast for at least 2 years!
And what are these bolt on Sri mods for 350bjp you talk off mate?
Old Apr 20, 2012 | 05:41 PM
saph4be's Avatar
saph4be
Oh do you know the cambelt interval too? I hoping it will be good as the place says it has a detailed service history!
Old Apr 20, 2012 | 06:19 PM
Nick 172 Sport's Avatar
Nick 172 Sport
50k and 100k
Old Apr 20, 2012 | 07:00 PM
Paulo P's Avatar
Paulo P
Personally I'd avoid the 2.5 engine because they suffer from head gasket failures and cracked ring lands.
5 speed boxes don't really handle much more than 350/350 but some can last with 400 but it's down to how it's driven. The rear suspension can also knock
Old Apr 20, 2012 | 07:09 PM
st220kyle's Avatar
st220kyle
5 speed boxes and the 2.5 engine dont have a great reputation in the subaru world, and instead of looking for bolt on sti parts, it usually makes more sense in the long run to just buy an sti in the first place, there are 6 speeds running 600bhp reliably
Old Apr 20, 2012 | 08:17 PM
Nick 172 Sport
have to agree lots off engine rebuilds with them headgaskets go and go again issue with bottom end 3k engine rebuid
Old Apr 20, 2012 | 08:19 PM
Nick 172 Sport
id go for a jdm model personally twin scrole
Old Apr 20, 2012 | 09:02 PM
daz1968's Avatar
daz1968
agree with above I went twinscroll widetrack jdm and have no regrets, had uk wrx before and spent far to much money on it and should have bought sti in the first place.
pics
but to answer question 2.5 wrx is good car but if you planning more than a basic remap then start with an sti
Old Apr 20, 2012 | 09:17 PM
stevieturbo's Avatar
stevieturbo
C**t
As others say, dont waste your money on the WRX, just buy an STI.
Old Apr 20, 2012 | 09:27 PM
focusRSgirl's Avatar
focusRSgirl
RS65666
ive had both wrx an sti a few years ago, and if id known the bullshit hassle (engine rebuild and dif problems) i was gonna get with the wrx i would of gone straight for the sti, (no problems had it remap and tweeked it a lil) its a better car to play with and less problem areas good luck tomorrow
saph4be's Avatar
saph4be
I changed my mind now I prefer the older shape (blob eye?) so gonna look for one off those in sti form! I think they look better and believe there more power from the start!
Old Apr 20, 2012 | 09:31 PM
RS Grant's Avatar
RS Grant
Made in Scotland
Much better plan mate.
They come from factory with 265bhp or 305 with PPP and 6-speed box/diffs, brembos, uprated engine, plus all the visual upgrades... they make far more sense these days now that values have dipped so low.
Cheers,
Grant
rallycross's Avatar
rallycross
Buy a 2.0 Sti.
Avoid the 2.5 models.
When 2.5 is tuned you will end up with serious oil consumption, from cracked piston rings or oval shaped bores.
2.0 Sti is much stronger.
Old Apr 20, 2012 | 09:34 PM
saph4be's Avatar
saph4be
I been looking all night and now my brain is fried so gonna call a few in morning!
Old Apr 20, 2012 | 10:33 PM
slammedorion's Avatar
slammedorion
If your going for a classic get a Type R ver 4-6.
If you do go newage get a sti.
Although there are issues with the 2.5's I'd still be tempted by the 2.5.
Upgrade the fuel pump, injectors, turbo, fmic, remap will see it well in the 400's with matching torque.
A 400bhp + impreza is a stupidly quick road car, you can't change gear quick enough.
I miss my old Type R.
Old Apr 20, 2012 | 10:43 PM
yellowsierra's Avatar
yellowsierra
Here´s mine
Bug eye STi Prodrive
305 out of the box so worth bearing that in mind
i´ve had mine decated,filter and exhaust and one remap later, 340bhp
Next jump is td05,20g turbo,650 injectors and pump will see me on the good side of 400.
The way these cars performe,i´d say 350bhp is a nice usable and capable car
Good luck in your hunt
Ian
Old Apr 20, 2012 | 11:00 PM
KSA-Cossie's Avatar
KSA-Cossie
Been looking at hawkeye sti's myself lately
Old Apr 20, 2012 | 11:25 PM
yellowsierra
pound per pony,they are hard to beat and make perfect sence
Old Apr 21, 2012 | 07:43 PM
saph4be's Avatar
saph4be
Made a complete u turn again! Put a deposit down on a cay hall zafira vxr! Saw it and loved it!
Old Apr 21, 2012 | 08:43 PM
slammedorion
Oh dear.
bobsworth
77
Mar 24, 2016 09:30 PM
Nov 1, 2015 06:53 PM
Kiran1600E
11
Oct 2, 2015 11:35 AM
rsguy
44
Sep 29, 2015 03:29 PM
Mc5506
Sep 29, 2015 09:06 AM
