Engine Oil Grade
Old Apr 19, 2012 | 10:55 AM
mcosworth's Avatar
mcosworth
Default Engine Oil Grade
Hello,
i would like your opinion on this:
I use 5W40 engine oil and i have noticed that it dissapears quite fast. In a couple hundred of k's it was almost empty.
In addition when i take the foot of the gas i can see that i have a small "ball" of smoke coming from the exhaust.
Do you think the problem may be in the oil used?
I live in Portugal, so i have to take the highest temperatures in account.
What would you recomend me to use as grade for a Portuguese Cossie?
Do you think the smoke can be a result of a use of engine oil too thin?
Thanks in advance,
Miguel
Old Apr 19, 2012 | 11:00 AM
rog's Avatar
rog
I'd say it's unlikely to be an oil grade issue you have, but I run 10/60 and probably about 80% of people on here as well. More related to engine/turbo wear or a breather issue if you're lucky.
Old Apr 19, 2012 | 01:05 PM
martysmartie's Avatar
martysmartie
Does it smoke when hot/cold or both?
The second number, i.e. 40 is the viscosity of the oil when hot, so it isn't that bad just slightly thinner than a 50 weight oil, however the 5 is the cold rating which obviously is a lot thinner than say a 10 or 15 weight.
Remember these are old engines and don't have the tolerances of modern engines and so it's too thin really, Ford recommended 15W/50!
Martin
Old Apr 19, 2012 | 01:48 PM
3FRD's Avatar
3FRD
I always run what ford recommend 15W50. Use that!
Old Apr 19, 2012 | 03:36 PM
mcosworth's Avatar
mcosworth
I believe it smokes both hot and cold.
It only smokes (and it isn t a lot) with the foot of the gas
However the oil level goes down a bit....
Old Apr 20, 2012 | 08:13 PM
martysmartie
The most likely cause is worn valve guides.
Martin
Old Apr 24, 2012 | 03:16 PM
Cozzie Bhoy's Avatar
Cozzie Bhoy
I've tried most of them and the best I've found is 10w 50 Fuchs Titan Race Pro S. Only one to use IMO..
Old Apr 25, 2012 | 10:25 AM
ECOS95's Avatar
ECOS95
2nd that.
Old Apr 25, 2012 | 10:26 AM
ECOS95's Avatar
ECOS95
My Ford manual says to use 5w50 fully synth, but that would be on a new engine.
Old Apr 25, 2012 | 12:20 PM
martysmartie
There does seem to be discrepancy's, the Rouse actually has a badge with use Shell 15W/50 on the engine.
Martin
Old Apr 26, 2012 | 08:41 AM
phs84's Avatar
phs84
Martin
or the turbocharger!i had the same years ago..the bearing of the charger wasn´t good anymore-new bearings and no smoke after that!it was the same like your´s(foot of the gas)
check your bearing clearence!i you´ve to much play in the direction of the axle then the charger will burn the oil.
cheers,
philipp
Old Apr 30, 2012 | 05:25 PM
mcosworth's Avatar
mcosworth
Thank you all.
I will try and change to a 10W50. For road use only can you advise me a brand?
Phs84, thanks for your tip, i will also check the Turbocharger to see if i get rid of the smoke.
Cheers,
Miguel
Old Apr 30, 2012 | 05:42 PM
fluxysaph's Avatar
fluxysaph
2nd that.
3RD that
Old May 3, 2012 | 10:50 AM
ECOS95's Avatar
ECOS95
Martin
Mines a ST Escort Cos.
I've run mine on anything from 5w50 to 15w50 (always Fully Synth) & most of the time you won't know the difference, except in cold weather when the 15w50 does take a bit longer to pump round the engine from cold.
I always think it’s best to find the one that works best for your engine & circumstances.
Old May 3, 2012 | 10:51 AM
ECOS95's Avatar
ECOS95
Originally Posted by mcosworth
Thank you all.
Cheers,
Miguel
This stuff is good.
Old May 3, 2012 | 08:34 PM
mcosworth's Avatar
mcosworth
Hi,
i'm finding it quite difficult to find 10w 50 Fuchs Titan Race Pro S here in Portugal.
For now i only found Total Quartz Racing 10w50 and Selenia Abarth 10W50.
Any experience on using these ones?
Regards,
Miguel
Old May 22, 2012 | 03:04 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Any good quality fully synthetic 10w50 will be fine. The 5w oil is definitely too thin for an old engine and a Cossie will drink this like a fish.
However, if you do track days, then it is worth tracking down the Titan oil (formerly Silkolene, so may still trade as that in your country?), as it's shear properties are way better than most others on the market.
Sheepdisease
Aug 30, 2015 09:11 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
Adam-M
Aug 26, 2015 05:53 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
