Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
1.6 Focus Ghia 06 plate.
Old Apr 18, 2012 | 09:32 PM
Death Angel's Avatar
Death Angel
Default 1.6 Focus Ghia 06 plate.
The back light on the odometer stays on after the ignition key is removed.
The radio is also showing the date and time.
Has anyone else had this problem and found a cure?
Old May 27, 2012 | 10:05 PM
am4nf's Avatar
am4nf
It stays on for a while but goes off eventually
Old May 27, 2012 | 10:09 PM
GVK.'s Avatar
GVK.
It should go off after about 10-15 mins after the key is removed.
Perfectly normal.
Old Jun 20, 2012 | 11:53 AM
Mehan's Avatar
Mehan
Perfectly normal.
same as mine also. Perfectly normal
liamT74
Sep 23, 2015 10:24 PM
Brickhouse
Sep 20, 2015 11:47 AM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
natehall
Sep 8, 2015 05:13 AM
Adam Graham
Sep 6, 2015 06:04 AM
