What Dump Valve
Right gotta get a new dump valve 4 my car.
Got an old original Bailey piston one at the mo, but it keeps siezing
Even on my older specs used to always split diaphragms so basicaly what do u guys recon is best on my car running 30psi on T4
Oh and if anyone got one for sale that would b suitable PM us would ya
Seen this one (pic below) adjustable boost setting so does that mean I could set it at say 20psi and the car would start dumping then so produce no more than 20 psi, and anyone had any experience of any like it
Steve
Steve
Originally Posted by Steve@SCC
You could send/take the Bailey 1 back and get it rebuilt
But tbh it done it on and off since new, wd40 would sort it for a couple days then need doing again
found a nice ptfe based lube
But this time even that stuff not doing it, always seems to do it when first starting have even taken it while driving lubed it and then put it back and still no good, but turn car off for say 20 mins and then ok, maybe it NOT the dv but recon it is.
Are the latter design Baileys any better /different ???
Steve
Give Bruce at Bailey a bell very decent chap to talk to 01763 246660
(numbers and names
Spec-r ones are good
GGR Group A dump valve
and prices on these plz gentlemen
Originally Posted by RSCAT
yep, me neither
Ill actually use enough boost to reap the benefits
