Fuel Injectors
I posted a few weeks back about the glow plug light on my car.
I replaced the accelerator and sensor and that didnt fix the problem. Unfortunately turns out its all four injectors gone.
I have been quoted quite alot so I am trying to source the injectors myself.
I have found 4 but the part number is different. The part number on my delphi injectors is R00501Z and the ones I have found for sale are R00101Z. The person selling them has assured me they will be ok for my car.
I dont want to go ahead and buy them if its going to be wrong as although alot cheaper than I have been quited, its still expensive.
Can anybody help me with this?
No, they won't fit the're a different shape, plus are earlier 'inferior' ones. 101Zs can be swapped for the 303Zs as they have a long nozzle and thin body, all the others have shorter nozzles and bigger bodies.
Thanks Dan, so I really need to just stick to the part number on my old ones (501z)?
It says on the injector body. You can see the code (it will be along with a bunch of other numbers, the 501z bit is at the end). You'll need a small mirror, or take a pic with a camera phone.
You don't have to, but you'll need a very long reach socket. I thought I'd be ok, but ended up buying one.
DixieTheKid
11
Jun 6, 2020 11:20 AM
