4x4 front hub info
Old Apr 11, 2012 | 06:09 PM
johnnysierra's Avatar
johnnysierra
Default 4x4 front hub info
i need to change my front shock and want to know if i need to disconnect the driveshaft or can i get enough leverage on it to take the shock out of the hub
Old Apr 12, 2012 | 07:27 AM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
Just under the hub bolt that holds the shock on to the hub and plenty of plus gas sprayed on and lever the hub off it using a scaffolding bar or similar on the bottom strut. Have someone to hold the hub though so you don't rip the cv boot apart. Be easier to take the calliper off too and rest it on a spray can saving taking it completely off and bleeding it.
Old Apr 12, 2012 | 07:46 AM
rog's Avatar
rog
I wouldn't reccomend it mate, you'll probably spend ages fucking around only for it to get stuck, far easier just to undo the ball joints and take out the shaft from the front diff which is a 30 second job itself.You'll be fighting against the ARB to get a big enough gap to get the shock in/out otherwise.
As above depending on your brake line length you might get away with leaving the caliper on, but watch you don't stretch the hose.
jessie_rs
11
Jun 3, 2019 04:57 PM
C2 MAK
Aug 20, 2015 09:46 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
track.focus'd
Aug 12, 2015 05:53 PM
Old ford
Jul 31, 2015 06:50 AM
