Help ? Clear pics of hydro clutch conversion needed
formerly beefy-rst-2
As title folks , going to put one on the mk three , anyone got any clear pics of the required mods to the bulkhead and more so the clutch arm.
Looking to see what's removed from clutch ( ratchet ect ) position of clevis , size ect.
Just looking to button up my pedal assembly at the weekend so rather do the mods now
Beef
Beef
I've got a couple of pictures but all the parts are now buried in the loft with loads of other Sierra bits so sizes will be a problem
Slave cylinder and rose joint from Merlin Motorsport.
You will need to make up a pair of 'top hat' bushes to nip up on the centre part of the rose joint and prevent the pedal from crushing.
The complete ratchet mechanism was taken off and I had to remove a bit of metalwork on the pedal assembly that was in the way, no pics of this though.
I have a hole press/ punch type tool if you need it does a very nice job and much tidier than a hole saw
same sort of thing as this
http://www.ebay.co.uk/itm/RUKO-10935...#ht_500wt_1156
also I can email you the instructions if you like?
http://www.ebay.co.uk/itm/RUKO-109350-PUNCH-HOLE-ROUND-35MM-/260963752120?pt=LH_DefaultDomain_3&hash=item3cc2a6 d8b8#ht_500wt_1156
if you wouldnt mind matt ill drop u a pm
JoeyBoyden
Jan 4, 2024 02:36 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
hazbaz1984
Ford Focus (All Models)
Jul 30, 2015 05:15 PM
