zetec turbo breaking (omex600) (mtx75 custom shafts)......
Old Apr 9, 2012 | 09:24 PM
ben ERST's Avatar
ben ERST
Default zetec turbo breaking (omex600) (mtx75 custom shafts)......
just broken up my s2 rs turbo zetec turbo these are the bits i have left as shell has sold. as i cant get on here alot please phone or txt me on 07889869988 if you are intrested in anything cheers ben.
2l zetec turbo engine : got 250 bhp out off this without proper map run like a dream!! only has 3m decom plate but head has been ported and polished and has arp con rod bolts. had new cambelt and water pump 6000 miles ago had new oil pump when built was only on the road 1 year so only done 13000 miles really. engine had done 90000 when i bought it.
£300
full omex 600 management package:
omex 600 ecu
full omex braided loom to fit zetec engine
focus rs injectors
rover side fed manifold which has had plenum welded on so fitts straight to zetec block
also where throttle body sits has be cut and welded on so it comes out straight
bigger throttle body
ally pipe with bend and samco pipe to intercooler
modified throttle cable
basically this is plug and play i fitted it all to my car in an afternoon so easy every thing you need!!
£850
SOLD!!!!!!!!!!!!
gizzmo electronic boost controller
with all wires and pipe work £80
mtx75 gearbox: good working order
£120
CUSTOM SHAFTS!!!
had these made for my conversion by dave mac shafts at a cost of £650
they have inners for mtx 75 and outer for rs turbo hubs
excellent condition
you will never see these for sale!!!! trust me lol
£400
SOLD!!!!
quickshift mtx75 gearlinkage :
modified to fit s2 rs turbo
£90
SOLD!!!!!
Airtec radiator black: this is only 6 months old perfect condition
£160
large slimline fan £30
smaller fan nearly new £30
grs big front mount intercooler
has slight damage to the back where fan come lose of radiator while running. pin prick hole!
£90
baileys frst oil swirl pot: good condition
£60
think my prices are ok but am open to offers on bits so just try me
will try and get some pics up cant seem to do it at the moment
cheers ben
Old Apr 10, 2012 | 06:14 AM
wilsonrs's Avatar
wilsonrs
Pm sent
Old Apr 10, 2012 | 04:21 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
How long are the shafts?
Old Apr 23, 2012 | 12:23 PM
lewisturbo's Avatar
lewisturbo
If you used a 1.8 zetec oil pick up pipe do you want to sell it? Thanks
Old Apr 23, 2012 | 02:44 PM
saman's Avatar
saman
wat make are the fans? an wat size are they?
robnock
21
May 13, 2019 05:29 PM
neil18
Mar 14, 2016 01:08 PM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
