Puma shifter on RS Turbo?
Old Apr 9, 2012 | 12:12 AM
PhilCook's Avatar
PhilCook
Default Puma shifter on RS Turbo?
Anyone done this conversion?
I believe that they can be fitted as they are but this moves the shifter backwards, meaning new holes have to be drilled to mount it to the floor. Does that mean that the gasket wont work so will piss water into the car?
Failing that, do they need chopping down to fit? If so, can anyone supply me with any info?
My standard RS shiter is awful
Old Apr 9, 2012 | 12:18 AM
fitted one on our track car ,with rs turbo box ,yes you need to drill holes ,but then we just made good the gasket after ,bloody good cheap mod
Old Apr 9, 2012 | 12:39 AM
PhilCook's Avatar
PhilCook
Any pics/advice? How would I "make good" the gasket?
Old Apr 9, 2012 | 02:31 PM
project rs's Avatar
project rs
why not fit a quickshift
Old Apr 9, 2012 | 10:11 PM
NATH-RSZT's Avatar
NATH-RSZT
I fitted one to my estate, bolts straight onto the box and it's 10mm shorter so hole need drilling. The whole centre console still fits straight back in. Will upload a couple of pics tommorow if you want?
Old Apr 9, 2012 | 10:37 PM
NATH-RSZT's Avatar
NATH-RSZT
Managed to do it on my phone
The 2 10mm bolts you can see are the back brace off the new selector.
Is a brilliant cheap mod, gear selection is as good as quick shift
Old Apr 10, 2012 | 05:57 AM
bennrst's Avatar
bennrst
Will this work on a frst
Old Apr 10, 2012 | 07:48 AM
PhilCook's Avatar
PhilCook
Cheers Nath.
So it's just a case of bolting it all to the gearbox, then drilling from underneath?
Old Apr 10, 2012 | 08:00 AM
Beach's Avatar
Beach
Looks good.
Any more advice or tips was thinking of buying a b and m but if this is just as good i wont bother
Old Apr 10, 2012 | 11:59 AM
Rogeyboy's Avatar
Rogeyboy
Does the stabiliser and everything fit...?
I tried this last year on a friends car and nothing seemed to line up, and the gear lever wouldnt self centre back to neutral.
Old Apr 10, 2012 | 01:44 PM
luke19790_3's Avatar
luke19790_3
you need the ib5 bix if you want it to self centre. yes it all fits apart from drilling extra holes
Old Apr 10, 2012 | 04:02 PM
PhilCook's Avatar
PhilCook
Can the lever be made to self centre by butering it with the RS lever mech at the gearstick end?
Old Apr 10, 2012 | 10:23 PM
NATH-RSZT's Avatar
NATH-RSZT
Originally Posted by PhilCook
Cheers Nath.
Ye I have the old style box found in all mk4's b5? I Think .not ib5 as that's the later version but should still fit.
Yes it litterally bolted straight to the box (both bars straight on) then lifted it up and marked the holes. Took me 20 mins tops.
I see no reason why it shouldn't fit a frst, may even be a direct swap as fez one is shorter that an escort.
I cannot stress how good and easy this mod is, if you've ever drove a puma you would know.
Heres a pic of my centre console all back together
Old Apr 10, 2012 | 10:35 PM
PhilCook's Avatar
PhilCook
Does it feel OK given that it doesnt self centre though?
I remember Jano saying he could make them self centre if you sent him a puma and escort linkages.
Old Apr 10, 2012 | 10:58 PM
NATH-RSZT's Avatar
NATH-RSZT
If you knock it out of gear it falls back to center, if In neutral and you pull it to one side it falls back to the middle. Is that self centering enough for ya lol
I havnt done any mods to it at all for it to do this.
Old Apr 10, 2012 | 11:16 PM
PhilCook's Avatar
PhilCook
Then thats fine and dandy for me.
Willbe off to the breakers this week to pick one up
Old Apr 11, 2012 | 11:53 AM
Rogeyboy's Avatar
Rogeyboy
Phil let me know how you get on please?
Old Apr 11, 2012 | 12:07 PM
PhilCook's Avatar
PhilCook
Will do fella
Old Apr 11, 2012 | 03:55 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Anyone running decent power should really be using an IB5 box anyway, there's so many about, so cheap and drop straight in!
Old Apr 11, 2012 | 04:00 PM
PhilCook's Avatar
PhilCook
They a lot better than the standard RSTurbo number?
Assuming they dont come with a diff though
Old Apr 11, 2012 | 04:03 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yes, the casing has more webbing meaning less flex under high torque, the bearings are bigger (like a CTS box), but no they dont come with a diff... The S2 LSD drops in though so not a problem.
Effectively an IB5 box is a CTS box without shot peened gears and a quaife diff.... for about £25!!!!
I ran my last IB5 for over a year (about 10k miles) with around 270bhp and it didnt break, prior to this I have broken three BC boxes with much less power... snapped main shafts, stripped teeth, etc.
Old Apr 11, 2012 | 06:21 PM
PhilCook's Avatar
PhilCook
Cool. So if my RS box blows up I will chuck a puma number in it. WIN
Old Apr 11, 2012 | 06:24 PM
luke19790_3
starter motor is in the wrong place on a puma, ka fits
Old Apr 12, 2012 | 07:20 AM
Rogeyboy's Avatar
Rogeyboy
I'd like to go for an IB5 box, but i just don't know what ratios etc etc to go for. I want standard-ish s2 ratios
Old Jul 11, 2012 | 11:55 AM
RS331's Avatar
RS331
Competition Technology
is it any specific year of puma you have to go for or fit or any year puma gear selectors and lever ?
Old Jul 12, 2012 | 09:55 AM
RS331's Avatar
RS331
can anyone answer that question ? any particular year of Puma, or does it not matter ?
Old Sep 1, 2018 | 04:29 AM
simonmcf's Avatar
simonmcf
Brining this up again - I have a puma shifter but don’t seem to have the colllar that fits to the body. Ideas on how to fix the shifter the body? Cheers
Old Sep 1, 2018 | 04:29 PM
haz87's Avatar
haz87
Collar? You need to drill two holes at the back of the linkage (shifter end) but not quite sure what the collar is you are referring to?
Old Sep 1, 2018 | 05:27 PM
simonmcf's Avatar
simonmcf
So I need to drill through the linkage housing on the puma one?
when I mean collar I’m talking about the idonized colour frame in post 6 above with the bolts come up.
Old Sep 4, 2018 | 08:06 AM
djmca's Avatar
djmca
Bring back old skool Ford
I have one of these lying in the garage for years, never actually fitted is because the non centering put me off and iirc the bars cross over underneath???
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
Ben26
Sep 3, 2015 07:55 PM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
