Head gasket
Doing the head gasket on my cosworth estate this week,does anybody have the loosening and tightening sequence please and what torque settings to go to,I will be using a 3 layer headgasket
i wouldnt use a multi if i was you jonsey
you really need the head and block decking to ensure full 100% flatness mate or you could have trouble later on
just use a small turbo escort cosworth gasket
more than man enough for what you run mate
Trouble is I need to get it done before next weekend and I've got either a group a gasket or the multi layer one,how hard and how much is a small turbo escos one going to cost and how hard to find one
grp a gasket is a small turbo gasket
dont use a multi layer steel one unless youhave the block decked aswell else it will not sit flush and will leak over time
and dont over tighten the bolts if you use a multi layer just same torque settings as std
and the small escort one has different fire rings ??
Mc5506
Oct 5, 2015 09:57 PM
