ball joint
Hi all,
i'm removong my drive shafts(or trrying rather), but dont have a socket big enough for the hub nut, so i'm going the long way around.
Now i have the brakes off, suspension off and steering off, but the lower control arm is giving me a problem, the ball joint.
I'm off to halfords now to but the 2 pronged removal tool, but how will i get this back together when im done.
Any help would be great!
Ta fella's
Ta fella's
whilst you're at halfords buy a socket and a breaker bar, that'll help you in the future, not worth pissing about working round hub nut IMO.
put it all back together, undo nut whilst on ground, undo lower arm and pop shaft out.
if you decide to carry on in the same route, just pop it back in with hammer taps to locate it in the right place.
Lol, i carn't beliele i didnt think of that?!!Maybe coz i'v had a beer, brain dead now.
Do you think my 1/2" ratchet will be up to the job and what size hut are they?
Wow, i feel stupid, lol!
Thanks for the great idea!
i think they are 30mm off hand.
1/2" ratchet may be upset, would need a pole putting through it if that's the plan, breaker bars are only Ł20, not even an hour in a garage would cover the cost of the tools, that's how i justify buying equipment.
Ok, il reattach the bit and bob iv taken off and go buy a 30mm socket, after checking with tape. i'm sure i have a scaffolding pole about too,
i'l be using a 1/2" drive tourqe wrench, would i be in risk of breaking that, it's rated to 210nm?
Ta mate,
you shouldn't break the torque wrench, but that isn't any use for tightening up after refit either, as the scale is too small.
breaker bar Ł20
socket Ł8 ish, job done and you have a tool that'll save you a fortune long term
breaker bar Ł20
What lengh bar do you recommend?
Thanks for the help mate!
just a regular breaker bar, 1/2" jobie.
i bought my first years back just after a 120piece hal pro socket set and it's frequently in use, from a tool supplier though, but they're pretty much the same, around 2' long.
I'l be down michane mart the first chance i get, 3ft bar @ Ł24 Inc vat, sound good i think, then get the hubs off.
That is all i need to get them off and i should be able to lever out the shafts, is that right?
Ta fella
Ta fella
SMILER258
Sep 28, 2015 09:04 AM
Mark V8
Sep 13, 2015 09:34 AM
