Engine problems s2
Old Apr 5, 2012 | 08:47 PM
Dave Hayemaker Jones's Avatar
Default Engine problems s2
Hi there for the last month I've been working on my car getting it all sorted I had to remove the turbo and manifold to change the radiator while I was there I got a mechanic in to change my Cambelt and water pump that's that now I've built it all back up I took it out put my foot down and it was chugging on off so I called mechanic back out to check timing was alright he looked over it said It was running fine so when I came home I took her out to get some petrol everything seemed fine when suddenly she cut out at the lights so started her back up revs kept dropping so held some revs on pulled off changed to second and there was a bang out the back and she cut out and wouldent start again got towed home left her to settle for a while turned her over she started give her some revs but then it seamed as if the revs wasent registering and she cut out again any ideas I got told the injectors needed cleaning so put some red ex cleaner in seems as if there's no combustion or there blocked up
Old Apr 5, 2012 | 08:56 PM
paul-h's Avatar
paul-h
Have you checked all the boost hoses for leaks? Could be a lot of things.
Old Apr 8, 2012 | 05:11 PM
Bump anyone
Old Apr 8, 2012 | 05:25 PM
studabear's Avatar
studabear
Did you check for air leaks on breathers and hoses etc???
Old Apr 10, 2012 | 02:38 PM
moesin2005's Avatar
moesin2005
i had a problem like this cheak if the bottom pully and the cam pully line up with the 0 on the plastic cam cover when i refitted my head i lined every thing up and the cam belt wouldnt fit on the cam pully so i moved it down to fit which made it slack and then when i tightened the tensioner it pulled the bottom pully round and advanced the timeing and it ran like crap took me ages to figure it out
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
Blown Hell
Aug 5, 2015 07:22 AM
