Sierra hatch Tailgates - are mk1 and mk2 tailgates the same?
Old Apr 4, 2012 | 10:14 AM
R4N SS's Avatar
R4N SS
Default Sierra hatch Tailgates - are mk1 and mk2 tailgates the same?
Are they the same, as i have a mk1 sierra 3dr and also have a 5dr mk2 hatchback and was wondering if the tailgates are exactly the same - they look to me but i have not had them side by side to compare as they are different locations.
ran
Old Apr 4, 2012 | 10:53 AM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
ran
They're not exactly the same, I'm sure lock and latch areas differ for one.
Old Apr 4, 2012 | 11:02 AM
R4N SS's Avatar
R4N SS
Cheers Martin, but can u swap the locks and latches over?
Apart from the above, are the actual tailgates identical?
Old Apr 4, 2012 | 11:38 AM
Mark V8's Avatar
Mark V8
Not sure about the mk1 to mk2 swap but there are two types of mk2 tailgate.
The early mk2 (up to 1990 IIRC) had a different wire grommet position on the right hand side compared to the later ones.
This requires a new hole to be drilled in the bodywork if you are replacing the earlier one with one from a newer car.
Old Apr 4, 2012 | 11:41 AM
RS500/364's Avatar
RS500/364
the same as in fitting as my xr4i has a mk2 on it ! got a make one here to !
Old Apr 4, 2012 | 12:12 PM
Iain Mac's Avatar
Iain Mac
The glass is bigger on a Mk2 so the metal frame is narrower. That means that if you are fitting an XR4i or Cosworth upper spoiler to a Mk2 tailgate, they will overlap the screen just a little.
The holes in the top for wiring and washer fluid are different, as are the wiring looms inside the tailgate.
Mk1 doesn't have a mounting hole for the radio aerial amplifier.
Lock and catch can be swapped over.
Mk1 hinges are welded to the tailgate. On a Mk2 they bolt on. So long as you have the Mk2 hinges they are a straight swap.
Old Apr 4, 2012 | 12:57 PM
R4N SS's Avatar
R4N SS
cheers for info guys - much appreciated
155lee
Sep 6, 2016 11:10 AM
sunburstred
Sep 9, 2015 11:24 PM
yorkie92
Sep 6, 2015 05:34 PM
Adam Graham
Sep 6, 2015 06:04 AM
