HELP sporka turbo
Old Apr 3, 2012 | 07:44 PM
Sportka turbo's Avatar
Sportka turbo
Default HELP sporka turbo
Hi guys
I'm currently trying to get my ka turbo up and running but have hit a bit of a problem.the engine is in place but my problem is that I have fuel upto the rail but it won't go through the injectors to the cylinders I have a spark and the fuel pump primes and also runs on during cranking,I've tested the injector plugs with my power probe and I have one live and the other wire on the plug is a pulsing live when cranking on all four plugs is that normal?it's a 1.6 cvh on ofac any help would be appreciated
Old Apr 6, 2012 | 09:12 PM
Churtz's Avatar
Churtz
hmm. well on your injectors it should have one live, and a pulsing earth. what management are you running?
matt
Old Apr 7, 2012 | 10:24 AM
NEEDFORSPEED's Avatar
NEEDFORSPEED
check your earths to the ecu pins 20 40 and 60 from memory?? all at one end of the ecu i think
Old Apr 7, 2012 | 02:53 PM
Sportka turbo
Hi thanks for the replies
Does the pulsing earth feed to the injectors come from pin 20,40 or 60?
Old Apr 7, 2012 | 04:16 PM
NEEDFORSPEED
pin 58 and 59 should be injector triggers but if you have a spark but no injector pulse you could have lost an earth have you checked for power at the injectors?
Old Apr 7, 2012 | 06:54 PM
Sportka turbo
I have fuel and a spark but the 2 pin plugs on each injector is showing one constant live pin and one pulsing live pin on all four?
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
