cambelt change on a mk1 focus
changing my cambelt on my 1999 2.0 mk1 focus, but cant find how so set crank pulley. read that there should be a bolt that you remove on the back of the engine, but cant find this bolt anywhere. its an early engine with 3 pulleys in the cambelt kit. any help would be great.
Where in Essex are you? I have the tools - let me know if you get stuck. I'm in Sudbury.
Just out of curiosity, did you make any timing marks prior to proceding? Something I always do out of habit - just in case.
im in wickford, quite away from Sudbury, but cheers anyway. the problem was one of the pulleys had come apart and belt was running on the bearing, it had cut right throught the belt. was so lucky it hadnt snapped. otherwise would have marked everything before removing it.
saph in dorset
Aug 14, 2015 10:10 AM
track.focus'd
Aug 12, 2015 05:53 PM
