1.8 zvh block and sump
I have for sale a 1.8 zetec block which was modified for zvh use, so has the crank breather blocked off, the block tapped for an oil return and another breather. It has the water ways in the block properly blocked off.
It is missing piston number two due to it melting as far as I can remember, as far as I know they are standard zetec pistons which have been machined to lower the compression.
It has a zetec oil pump on it, standard crank, it comes with the water pump adapter plate for the cvh water pump and block has been tapped for bolts for cvh cam belt tensioner/idler. The block has been painted blue, but can always be repainted.
The above mentioned is £75 collection only or£100 collection only with a escort/fiesta zetec sump, windage tray and pick up pipe. Will take senseable offers on it, but is is collection only from Birchanger, herts/essex.
PM me for details or contact me on 07791262927
Thanks
Thanks
