T piece in brake boost pipe
Old Apr 1, 2012 | 08:04 PM
FezzyST's Avatar
FezzyST
Default T piece in brake boost pipe
is it safe to put a t piece or vac manifold in the brake booster pipe?
Old Apr 1, 2012 | 08:17 PM
studabear's Avatar
studabear
Yeah if proper decent connectors are used.
Old Apr 1, 2012 | 08:39 PM
FezzyST's Avatar
FezzyST
something like this http://www.ebay.co.uk/itm/Stealth-Bl...ht_1138wt_1344
Old Apr 1, 2012 | 08:50 PM
studabear's Avatar
studabear
you could remove your inlet and then drill and tap for a vacum take off, what car is it for?
Old Apr 1, 2012 | 08:58 PM
FezzyST's Avatar
FezzyST
its for a fiesta st turbo. i have just got a new inlet alloy inlet from the states which
only has 1 small take off apart from the brake boost pipe.
i dont think the wall is thick enough to tap.
Old Apr 1, 2012 | 09:02 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
You'd need to fit it in the line before the non return valve, otherwise it will always give the servo vacuum rather than the changing vacuum in the manifold.
Old Apr 1, 2012 | 09:23 PM
FezzyST's Avatar
FezzyST
i cant see a valve anywhere on the pipe
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
focus2351
Sep 9, 2015 09:33 PM
markk
Sep 9, 2015 08:11 AM
hopper350
Sep 4, 2015 12:53 AM
