3 DR Cossie Engine Noise
Old Apr 1, 2012 | 04:14 PM
timosmob's Avatar
timosmob
Default 3 DR Cossie Engine Noise
Hi
Can't believe what a fool I have just been, have been changing the cam belt on my 3dr cossie and didn't realise the tensioner was not done up properly and on start up the cam belt come off. On re-assembly the engine appears to be running fine but there is a loud tapping noise under the cam cover. Any suggestions please.
Old Apr 1, 2012 | 04:27 PM
Sonic Boom's Avatar
Sonic Boom
Bend Valves!
You're going to have to take the head off to check properly, you could do a compression test to give you an idea.
Rich
Old Apr 1, 2012 | 04:36 PM
BRAMMER's Avatar
BRAMMER
It's timed up right is it? To the left of the peg on crack pulley
Old Apr 1, 2012 | 04:45 PM
timosmob's Avatar
timosmob
cams at 3oclock and 9oclock and crankshaft pulley at tdc is that right?
Old Apr 1, 2012 | 05:26 PM
david 100's Avatar
david 100
You dont use the grove on the crank pully you use the peg nearest to it, if you use the grove in the crank pully it will tap, but if your lucky it wont have done any harm,
Old Apr 1, 2012 | 05:29 PM
john_p_b's Avatar
john_p_b
Head will need coming off, no doubt about it even at idle you won't get away with having it throw the belt off.
Old Apr 1, 2012 | 06:48 PM
timosmob's Avatar
timosmob
Thanks very much David 100 , you was spot on. Re-timed up on the mark you said all ok, no damage, running fine. One very luck man
Old Apr 1, 2012 | 07:09 PM
Rsmat's Avatar
Rsmat
Well done mate glad someone's had some luck today.
Old Apr 1, 2012 | 07:11 PM
Sonic Boom's Avatar
Sonic Boom
I'm very surprised you got away with that.
I wouldn't be that lucky.
Rich
malkiemac3579
Jul 14, 2017 12:10 PM
Churtz
15
Aug 13, 2015 06:40 PM
track.focus'd
Aug 12, 2015 05:53 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 07:06 AM
MARKYMARKONE
Aug 2, 2015 09:33 PM
