S2 zetec turbo water hoses?
Old Mar 31, 2012 | 04:31 PM
GMMS's Avatar
GMMS
Default S2 zetec turbo water hoses?
anybody do a kit?
Old Apr 4, 2012 | 05:40 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
You need a small reducer water pipe side. Then use a CVH thermostat housing on the zetec head the other side making it a direct fit.
Old Apr 4, 2012 | 06:15 PM
Karlos G's Avatar
Karlos G
Balls Deep!
If your using a black top water pump then all you need to do is fit the CVH stat housing, pipework all fits.
Old Apr 13, 2012 | 09:45 PM
HirenRS's Avatar
HirenRS
turbovh
if using a silvertop can i block the extra hose which comes off zetec stat housing be blocked off and also if i am using a efi manifold do i levae the water pipe that used to go to it out?
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
