Series 1 side wing indicaters whats the score??
Old Feb 26, 2005 | 04:39 PM
Rippers's Avatar
Rippers
Monte Geek
Default Series 1 side wing indicaters whats the score??
I'm changing the wings on the Series 1. It had side indicaters but the new wings don't have the holes. I don't particually want the side repeaters but do I have to have them with the series 1? is there a law on age of cars having side repeaters? Seems most b-reg series 1's don't have them?
..also the existing side repeaters, without them will the indicaters flash quicker as if one of the bulbs has gone out (not sure if the series 1 had that advanced technology )
Old Feb 26, 2005 | 04:47 PM
AJC's Avatar
AJC
indicator will flash quicker, the 1986 series 1 all had side repeaters, some C reg
and D reg.
Old Feb 26, 2005 | 06:30 PM
Rippers's Avatar
Rippers
Monte Geek
So do I have to have side repeaters if I had them before legally?
To stop the bulbs flashing quicker could I cut the bulb holder off and strip the wires back and join them to close the loop or would that blow a fuse?
I'm not convinced my series 1 originally had side repeaters anyway as the hole was perfectly round and the indicaters where siliconed on.
Old Feb 26, 2005 | 06:42 PM
AJC's Avatar
AJC
i dont think it will matter, if 1985 c reg pass MOT's then i am sure a 1986 one will,
they only put approx year car was first used on MOT's certificates which will be
1985, i am not sure about the twisting of wires together,
have a look at your V5 as it will state whether its a 85/86 and you will know
whether it originally has indicators or not
Old Feb 26, 2005 | 07:14 PM
nigel b's Avatar
nigel b
paul
the bulbs wont flash quicker as its on the same circuit
if your car was registered on or after 1st january 1986 it has to have side repeaters
my car is 1986 on a c but i tell the mot its a 1985 car so i dont have to have them on the wings
Old Feb 26, 2005 | 07:44 PM
Rippers's Avatar
Rippers
Monte Geek
Not had the V5 back yet so can't check.. please be '85.. please be '85..
How long do V5's usually take bet the geezar hasn't even posted it yet
(had the car three weeks)
Old Feb 26, 2005 | 07:47 PM
Rippers's Avatar
Rippers
Monte Geek
just checked the little V5 cut off slip 19/08/1985
Old Feb 27, 2005 | 12:39 PM
DazC's Avatar
DazC
If you join the wires it will blow the fuse.
Try it without the bulbs first and see what happens. Most early cars ignore the side repeators if they blow a bulb and flash a normal rate.
Old Feb 27, 2005 | 01:02 PM
stuart collins's Avatar
stuart collins
U dont need them i havent got them on my s2 and it passed a mot , as long as u can c the front indicator flashing when stand by the rear quarter u dont need them
Old Mar 24, 2005 | 08:35 PM
tonyturbo's Avatar
tonyturbo
Old Mar 24, 2005 | 08:36 PM
tonyturbo's Avatar
tonyturbo
my series 1 never got them after the new wings were fitted. passed mot no problem
Old Mar 24, 2005 | 11:02 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
My S1 did have them, but one side got new wing and other hole patched up, no probs with flashing etc, jus cut the wires off the other day too.
Old Mar 25, 2005 | 08:55 AM
Ferd's Avatar
Ferd
Default S1
Hi
It sounds as if your indicators were added at a later date. And as Nigel b stated if the car was first registered before Jan 1st 1986 then it dose not need them and should not have them.
My first S1 had them and I changed them for a pair of small oval one’s they looked really good.
It’s your choice if you want them or not.
Ferd
155lee
Oct 27, 2015 04:55 AM
Shaunc
Escort Range
Sep 22, 2015 06:38 PM
pabloXR
Sep 21, 2015 12:42 PM
Bransby
Sep 14, 2015 08:54 PM
BRAM
Sep 8, 2015 07:11 AM
