Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
focus gearbox
Old Mar 23, 2012 | 08:33 PM
lufcfocus19's Avatar
lufcfocus19
Default focus gearbox
My focus 2.0l mk1 petrol grinds into 2ND and 3RD. lookin to replace the box. is an st box an easy mod? or a diesel box?
or does anybody else have any ideas of a decent mod to do?
thanks ppl
Old Mar 24, 2012 | 11:55 PM
Straight_4_N/a's Avatar
Straight_4_N/a
thanks ppl
focus 1.8 Ib5
less trans loss (ib5 avrages 15% where the mtx75 is 17%) and you get shorter ratios so better 0-60 but lower top speed (ib5 still good for 135+) and you can fit the 1.8 flywheel at the same time which is lighter so you get a free reving engine.
but its not a good box for high power (ie 250bhp+) but good for lower power cars
you would need
pair of drive shafts
gearbox
flywheel
gear cables
gear selector (gear stick)
and the rev switch plug from an ib5 (im pritty sure thay differ to mtx75)
Old Mar 25, 2012 | 05:30 PM
lufcfocus19
thanks great info. only running at 131bhp.
Old Mar 25, 2012 | 06:34 PM
martysmartie's Avatar
martysmartie
Standard then, thing I would ask myself though is why did Ford fit the MTX, if they could get away with fitting the IB5, like they did on all other petrol models (Barring hot models) there must be good reason?
If those ratios are short I dread to think what the MTX is like, I have always found the IB5 to be tall gearing.
Martin
Old Mar 26, 2012 | 11:02 AM
Straight_4_N/a
Martin
Because ford use what ever box thay have to hand, like in the mondeo and fiesta st both same engine but fiesta uses ib5 mondeo mtx75.
First is alittle bit taller but every other gear is shorter than a mtx75.
Old Mar 29, 2012 | 08:06 AM
lufcfocus19
its an awquard job changing the box, had it out once to do the clutch ( not keen on doing it again) but its getting realy bad now. i think ill stay standard to save the hastle. thanks for all your advice folks!
Bransby
Sep 11, 2015 09:12 PM
fordfiestamk3
Sep 11, 2015 12:52 PM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
gingeRS
Sep 4, 2015 06:29 PM
