Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Focus Engine Management Light Flickering
Old Mar 22, 2012 | 10:35 PM
machbuffet's Avatar
machbuffet
Default Focus Engine Management Light Flickering
Hi folks
We have a 2002 petrol 1.6 lx with 67,000 miles.
The engine management light occasionally flickers after starting. It usually happens when the car has been sat for a while, or after heavy rain or it's been washed - damp weather.
It doesn't flash, nor stay on steadily - it only ever flickers - bright, dim and bright again. Once the engine gets warm, it goes out.
No fault codes stored (proper ford specialist, not diy assessment)
Car drives fine and shows no issues at all.
Had read somewhere that water can seep through the washer jets and deposit onto the leads and coil pack. I have from time to time sprayed the whole HT assembly with WD40 and it seems to help.
By the way, it didn't happen all through the summer, just started in winter.
Just to clarify again, the light doesn't flash nor stay on steady - it just flickers for a while (3 to 6 mins) then goes out and stays out for the rest of the journey.
Any help or advice greatly appreciated, we're selling it soon and wouldn't want it flashing on the test drive.
Thanks in advance
Baz
Old Mar 22, 2012 | 11:45 PM
GVK.'s Avatar
GVK.
Washer jets can leak, but you'd see rusty water around the plugs if so, remove the leads to check this. There are modified washer jets with a gasket from Ford.
It does sound like you could have a slight misfire, as when the MIL is flashing it should register a fault, even as a pending code.
edit -re-read your post and you say it doesn't flash, have not seen that before and I have worked with Focus since it was introduced!
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Focus Steve
Ford Focus Range
Aug 3, 2015 09:09 PM
Old ford
Jul 31, 2015 06:50 AM
