Genuine RS three spoke steering wheel with RS boss - Fiesta, Escort etc.
Hi guys
I've got a 3 spoke RS steering wheel in good condition, leather a bit worn as you can see from pic, but pretty good overall. Comes with an as new mk3 Fiesta boss which fits Mk2 Fiestas, and I think also Escort XR3 / S1s? Comes with a horn press centre. Will also come with mk2 Fiesta steering column cowling modified to fit, if required.
I sourced the wheel and the boss separately, along with brand new O/S bolts to secure the boss to the wheel hub. Cost me a lot more than I'm asking.
£120 including recorded postage in the UK!
PM me if you want it,
Paul
Paul
Hi, what has to been done to the steering column cowling to make this fit? is this because its a mk3 boss? (I thought they just bolted straight on with the correct boss) could you also tell me a bit more about the condition of the leather, will it clean up or is it quite worn?
cheers, Dan
cheers, Dan
Well I was offered two that made me wince - one for £100 and another for £130.
They were Mk2 ones though, which I'm told are rarer. But for me, getting hold of a second hand cowling set to file out a bit and then fitting a Mk3 boss made much more sense.
JoeyBoyden
Jan 4, 2024 02:36 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
however sure it will sell pal, dont see 3 spokes that often now
