Can it be done?
Hey people,
I need to remove a 1.4 cvh engine, but really want to leave the box in place.
So i want to take the engine up and out, can it be done this way. If so, do i need to remove anything other than engine mount, bellhousing bolts, manifold and bonnet?
I have just repaired one cvh, head and clutch which was a big job for me, now i need to swap a 1.4 cvh for the same.
Thanksfor any help!!
The head is off so nearly all the pipes and cables are off, i'l do the rest tomorrow.
I dropped the box and engine last time and don't want the job again, i want to keep it simple even if it's more work.
So the pullys will clear the bay and there is enough room to slide the engine off the gearbox dowles?
Thanks!
Thanks!
