No fuel past metering unit and melted relay! help!
Old Mar 18, 2012 | 08:44 PM
webbie227's Avatar
webbie227
A Webb
Default No fuel past metering unit and melted relay! help!
Escort RS Turbo series 2
Driving home and cuts out and won't start up at all!
the pump primes up to metering unit but no further
there is also no spark!
checked the fuse box and the INJ fuse had melted and check the pink relay under the dash and that had got hot and melted the plasic casing to some extent
i ordered a new relay to try solve the problem
will this work?? did itr melt coz of the relay was knackered?
why havn't i got spark? i have power to the coil
please help guys im totaly stuck!
many thanks
Old Mar 18, 2012 | 10:09 PM
the fox's Avatar
the fox
gettting hot common problem with pink relay! melted a couple myself the 1 got in now I"ve drilled a couple of holes in to the caseing to aid ventilation tbh dont know for sure if it helps stop melt down but makes me feel better and it has out lasted previous two! As for fuse melting not had that prob! u
Old Mar 19, 2012 | 06:17 PM
paul-h's Avatar
paul-h
Changed the dizzy, plugs & leads? Tackle one problem at a time and take it from there.
Old Mar 19, 2012 | 07:14 PM
XR2's Avatar
XR2
many thanks
Two solutions:
1. check the fuel pump connections. Especially when the earth connection is bad (what you'd expect after 25 years) or the fuel pump is worn the pink relay usually gets hot or melts down like yours did. That's probably the cause that the priming still works but the fuel pump won't run when you try to start the car
2. dizzy connector. The fuel pump relay gets it signal directly from the 3pin dizzy connector. Sometimes the pins inside the connector come loose and the relay won't get a signal. Fuel pump primes, but won't run when cranking.
But first check solution 1. Especially the fuel pump connection.
TPM961
Jan 15, 2018 10:50 AM
155lee
Oct 27, 2015 04:55 AM
15
Oct 7, 2015 03:43 PM
kevin36
Sep 9, 2015 11:12 AM
kevin36
Sep 8, 2015 12:23 PM
