radiator to use on a escort rst s2?
Old Mar 14, 2012 | 10:49 AM
saman's Avatar
saman
Default radiator to use on a escort rst s2?
hi ther just a quike question what is better to use a copper core radiator or a alluminium radiator?
Old Mar 14, 2012 | 01:53 PM
beaver rs 88's Avatar
beaver rs 88
in the garage
Always been told copper ones are better. Better heat dissipation and all that.
Old Mar 14, 2012 | 03:26 PM
lewis.philcox's Avatar
lewis.philcox
Be a myth that...
This is a on going argument through out passion ford if you search your see plenty of threads relating to this..
the copper radiators have plastic ends on them.
The alloy rads have a larger surface area and metal ends and are "High Flow" apparently.
i have a alloy rad in my rs, they are a good upgrade if your using a full front mount intercooler as it makes mounting the cooler a bit easier but as for heat transfer and dissipation people have said theres not a lot of difference.
My RS hovers around half way all the time but again remember the temp gauges are beyond inaccurate
JK12
33
Apr 26, 2021 12:09 PM
yatta
May 21, 2016 10:31 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
cossirob
Sep 3, 2015 09:17 PM
