Focus mk1 reverse light switch...
Old Mar 8, 2012 | 03:53 PM
Camel Fiddler's Avatar
Camel Fiddler
Resident Camel Stalker
Default Focus mk1 reverse light switch...
How's it wired up? Mine only comes on with the clutch about 1/2 way up. I know my gearbox tripod mount snapped just After I bought the car while I was driving which meant the box hit the floor but actually sat off the floor as the o/s engine mount took the strain and just wondering if it's related. If so could I have damaged any wires or earths etc?
Old Mar 8, 2012 | 09:37 PM
Camel Fiddler
Anyone know?
Old Mar 8, 2012 | 09:56 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
just gonna go have a looksy at some pictures.
also the dogbone mount would stop it dropping too far, wouldnt damage wiring at all
Old Mar 8, 2012 | 09:59 PM
GVK.'s Avatar
GVK.
Clutch doesn't have bugger all to do with the reverse switch. Do you mean you have to lift up the clutch a bit to engage reverse?
12v (battery voltage) one side of the switch, then when the switch is engaged it puts 12v on the other side of the switch, putting the reverse light on.
Is your's an iB5 or MTX box?
Old Mar 8, 2012 | 10:06 PM
Cossie Sean
very top of the box is the 2 pin plug, same plate that the gear linkages are bolted to.
GVK, MTX75 fella
found a step by step guide for you dude!
http://www.focusfanatics.com/forum/s...d.php?t=160808
Old Mar 8, 2012 | 10:07 PM
SiST's Avatar
SiST
Engaging reserve completes the circuit and then the lights come on - clutch wont affect that.
The reverse switch is at the top of the mtx75 and the front of the ib5 so doubt its damaged or a wires been pulled tbh
Old Mar 8, 2012 | 10:08 PM
GVK.'s Avatar
GVK.
MTX switch
http://www.fordpartsuk.com/shop/ford...1361_c_104.htm
location - http://www.fordforumsonline.com/foru...ght-switch.jpg
Old Mar 8, 2012 | 10:09 PM
SiST's Avatar
SiST
Also if anyone has any spare connectors to go on these switches, i will gladly buy them off you.
Old Mar 8, 2012 | 10:10 PM
SiST's Avatar
SiST
http://www.ebay.co.uk/itm/Genine-For...item335881540f if you need to replace it
Old Mar 8, 2012 | 10:31 PM
Camel Fiddler
When I put the car in reverse or am reversing the car and the clutch is near the floor the light isn't on but if I raise my foot up it reaches a point where the light works. Put my foot down again slightly and light goes off again. It's weird.
I believe it's an iB5 as its a modified 1.8 blacktop from Ford.
Old Mar 8, 2012 | 10:49 PM
GVK.'s Avatar
GVK.
You could have a chafed wire or something and when the engine rocks when the clutch engages it's pulling on the wire.
Old Mar 9, 2012 | 06:15 AM
Camel Fiddler
I'll take the battery n that out when I get a chance and take a look see if I can see wiring that's loose or damaged or anything unusual. So there's no earth leads or main loom down there?
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
jaysoc1
Aug 20, 2015 08:18 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
saph in dorset
Aug 14, 2015 10:10 AM
hazbaz1984
Ford Focus (All Models)
Jul 30, 2015 05:15 PM
